Toymods » Tech & Conversions » smoking airconditioner
beterthenu
Dubbo NSW
smoking airconditioner Thu, 03 March 2005 12:00 Go to next message
hopefully someone can steer me in the correct direction before i start dismantling the unit.
while driving in my 90s model camry, a thick black smoke started to emerge form the air vents.
would this most likely to be the fan motor dieing?
[Updated on: Thu, 03 March 2005 12:46]
1G-GTE KE70
Re: smoking airconditioner Thu, 03 March 2005 12:06 Go to previous messageGo to next message
maybe some evil mastermind is releasing a mind control agent into your car via the air con ducts? Evil or Very Mad Evil or Very Mad
Fattony
Re: smoking airconditioner Thu, 03 March 2005 12:28 Go to previous messageGo to next message
Usually a honda does that when you drop a burnout
EldarO
Perth, WA
Re: smoking airconditioner Thu, 03 March 2005 15:41 Go to previous messageGo to next message
our VT started doing this mate, holden quoted about $1400 to fix the shit, simply because the airbag had to be "detonated" and replaced, $4 worth of sealer and almost 18 months later, shes still not smoking Razz
ill check and see what the problem was and get back to you Smile
Eldar.O.
Celica_John
Re: smoking airconditioner Thu, 03 March 2005 20:58 Go to previous messageGo to next message
EldarO wrote on Fri, 04 March 2005 02:41
Eldar.O.
I fixed this problem on my brother's VT. The VT's heater core had a seal then the inlet and outlet where bolted in. This seal went and coolant was leaking past the seal, burning and smoking out the vents. The new heater core we got from holden didn't have the seal . . it was all one piece.
I always thought that it smelt a bit like pancakes mmmmmm
EldarO
Perth, WA
Re: smoking airconditioner Fri, 04 March 2005 02:34 Go to previous message
Celica_John wrote on Fri, 04 March 2005 04:58
ahahah, that it did Smile
mum didnt like getting a car full of smoke on the way to work in the morning, bah, weakling, i told her to just open the window for a while Razz
Eldar.O.
Previous Topic:CCA cold cranking amps
Next Topic:LSD information for sprinters
Current Time: Sun Nov 1 19:02:48 UTC 2026
Total time taken to generate the page: 0.015761852264404 seconds
