Toymods » Tech & Conversions » Engine/gearbox shake??
ta2272
icon2.gif  Engine/gearbox shake?? Fri, 04 March 2005 01:47 Go to next message
I have a shake which is really noticable, when you rev the car past 6 thousand revs there is a shake which is mainly heard from the gear stick shacking, it is conderning enought that i change when i hear the noise coming on.
I dont think it is related to the tailshaft as when i put my foot on the clutch the noise stops.
Any ideas guys?
Jason
stradlater
Arthurs Creek, Victoria
Re: Engine/gearbox shake?? Fri, 04 March 2005 02:36 Go to previous messageGo to next message
engine/gearbox mounts
IRA11Y
Club Member
Re: Engine/gearbox shake?? Fri, 04 March 2005 03:08 Go to previous messageGo to next message
when was the last time you had your flywheel off?? id say theres some loose bolts on it Smile, or worse theyve started to shear.
if its not the mounts thats the next best place to start looking
ta2272
Re: Engine/gearbox shake?? Fri, 04 March 2005 05:27 Go to previous messageGo to next message
left engine mount is half gone but half is still connected do you think this could be my problem?
Jason
RobST162
Re: Engine/gearbox shake?? Fri, 04 March 2005 05:31 Go to previous messageGo to next message
well.. depends what you mean by "half gone" if it's got a crack in one of the rubber holders that's enough to cause the engine to shift around more
EldarO
Perth, WA
Re: Engine/gearbox shake?? Fri, 04 March 2005 05:46 Go to previous messageGo to next message
in a performance car, if its not rock solid, replace it :/
Eldar.O.
ta2272
Re: Engine/gearbox shake?? Sun, 06 March 2005 08:57 Go to previous messageGo to next message
just another thought it is a supra g/box in a ta22 what if the tunnel isnt wide enought and when it revs to a certain point (twists) it hits the tunnel wall and i get vibrations.
Jason
Re: Engine/gearbox shake?? Sun, 06 March 2005 09:07 Go to previous messageGo to next message
It won't.
ta2272
Re: Engine/gearbox shake?? Sun, 06 March 2005 09:55 Go to previous messageGo to next message
there is also a noise if you put your foot on the accelerator quickly, it makes a knokcing noise which you can feel comeing threw the floor pan.
Mookie
Tassie
Re: Engine/gearbox shake?? Mon, 07 March 2005 05:34 Go to previous messageGo to next message
Is there plenty of clearance between the gear shift and the tranmission tunnel ?
Re: Engine/gearbox shake?? Mon, 07 March 2005 13:42 Go to previous message
A misaligned tailshaft will do that. Is the gearbox mounted at the correct height?
Previous Topic:3t info
Next Topic:Clutch
Current Time: Tue Oct 20 12:49:19 UTC 2026
Total time taken to generate the page: 0.029448986053467 seconds
