Toymods » Tech & Conversions » 600cc turbo to suit
Meat_rack
East Maitland NSW
600cc turbo to suit Sat, 05 March 2005 14:56 Go to next message
i know this may be in the wrong forum but id ld like to know what turbo could you put on a 600cc motorbike motor without it being too big and lagging up tp the shithouse. its a multy valve DOHC motor out of a gsxr600. If anyone could tell me what kind of boost would be suitable to run what kind of turbo
7M-Brisbane
Re: 600cc turbo to suit Sun, 06 March 2005 00:33 Go to previous messageGo to next message
Kawasaki released a factory turbo version of the GPZ in the 80's. It had a 750cc engine but quite a small turbo. A common upgrade is the T2 off an ET Pulsar, so I would suggest that the sizing would be reasonable for your GSXR600 at a low boost level. Remember that motorbikes run very high compression and ambitious timing to make the power that they do.
That said, for better response (given that the 600's are already quite 'top endy') you may want to look at a ball bearing turbo. I believe that Garrett have a flavour of their GT ball bearing turbos that would suit your motor - I think they go as small as 200hp. Don't quote me on that, you'll have to speak to a turbo shop.
If you're looking for advice on bike turbo conversions, you can't go past S&R Pro who have a number of turbo bikes (mostly Suzukis) and plenty of experience. They do ride in-ride out conversions for about $10k on injected sportsbikes. Depending on what year your motor is it may be carb'd, which means it would be MUCH cheaper, probably around $3k depending on what turbo you chose.
At the end of the day though, it would probably be easier and cheaper to trade up to a GSXR750/1000 and be done with it. From memory the 05 thou's have something phenomenal like 165rwhp and weigh 168kg... but you can get onto an 02/03 model for about $12k, and about half that after your trade-in (depending on model). Worth a thought.. but I know it's not as cool as a turbo bike Smile
MR 1JZ
Re: 600cc turbo to suit Sun, 06 March 2005 01:41 Go to previous messageGo to next message
one CT12 might do the job, might be a little big, but at least its steel wheeled and good for around 80rwkw
Soarer
Wollongong
Re: 600cc turbo to suit Sun, 06 March 2005 02:37 Go to previous messageGo to next message
What about a turbo of a Suzuki Cappucino or Daihatsu Copen ? Both are 6xx CC engines, so would be well suited to the application.
Meat_rack
East Maitland NSW
Re: 600cc turbo to suit Sun, 06 March 2005 02:50 Go to previous message
id like a motorcycle motor because they already dovelop a large mount of power. I am aware of the copression situation and the motor will be built to suit. Its not to go in a motor bike its for a compact speedcar. If i was to get the block o-ringed (i think is the right term) how much boost can i run, the power goal is maybe 200hp.
[Updated on: Sun, 06 March 2005 02:52]
Previous Topic:gears aren't going in!
Next Topic:1JZ MX73 high idle
Current Time: Thu Nov 19 07:29:21 UTC 2026
Total time taken to generate the page: 0.013367891311646 seconds
