Toymods » Tech & Conversions » gears aren't going in!
T_is4turbo
Liverpool/sydney
gears aren't going in! Sun, 06 March 2005 02:28 Go to next message
g'day guys
have a lil problem relating to the gearbox(suzuki vitara)
its not going into gear when the engine is on, but its ok when engine is turn off.
could it be the clutch?
mick
toowoomba qld
Re: gears aren't going in! Sun, 06 March 2005 02:43 Go to previous messageGo to next message
maybe. If you can select reverse without any gear clash usally means there is a good chance your clutch is operating properlly.
It may be something in the gear box. such as you may have worn or damaged selctor forks maybe?
or as stupid as this sounds,maybe your gearbox has either insuffecnt oil or the oil is the wrong grade? (that's all I can think off mate) hope this might be oof some help Smile
fatboy
January 2005
Re: gears aren't going in! Sun, 06 March 2005 02:50 Go to previous messageGo to next message
your clutch is out of adjustment
T_is4turbo
Liverpool/sydney
Re: gears aren't going in! Sun, 06 March 2005 02:56 Go to previous messageGo to next message
thanks mick/fatboy
Smile oil is ok, but it could be the wrong oil grade, or like you said the selector folks, or the clutch setting like fatboy said, taking it to the mechanic to have it look at tomorrow
maybe i brother should just send the Suziki to the scrapeyard and get a Toyota, this should fix the problem Smile hehehe
thanks guys
[Updated on: Sun, 06 March 2005 02:57]
berad
Re: gears aren't going in! Sun, 06 March 2005 03:16 Go to previous message
check the slave cylinder... i had the same problem.. check the fluid in the master cylinder to
Previous Topic:Crown 1UZFE ECT speed sensor inputs **now with pics**
Next Topic:600cc turbo to suit
Current Time: Thu Nov 19 08:06:02 UTC 2026
Total time taken to generate the page: 0.0048770904541016 seconds
