Toymods » Tech & Conversions » Need Help Camry drinking Fuel
Driften ZZE123
Need Help Camry drinking Fuel Sun, 06 March 2005 04:15 Go to next message
Hey guys my dads camry is starting to act up it has been drink fuel constantly this week and i'm not sure wats wrong with it. Usually the car can survive 2weeks on $60 worth of gas now it takes around $50 worth of petrol in a week. Any ideas on what could be wrong. I've check the fuel injectors and there seems to be nothing wrong.
Dale_ta22
Forster NSW
Re: Need Help Camry drinking Fuel Sun, 06 March 2005 05:10 Go to previous messageGo to next message
Check you are getting good sparks, check the timing too. I know you said you checked the injectors, but maybe the cold start injector is stuck on.
FWDCelica
sydney,nsw.oz.
Re: Need Help Camry drinking Fuel Sun, 06 March 2005 05:41 Go to previous messageGo to next message
Dude,
What year model Camry ?
4 or 6 cylinder ?
Spark plugs would be the 1st thing I would check, then maybe blocked Air Filter.
T.
mick
toowoomba qld
Re: Need Help Camry drinking Fuel Sun, 06 March 2005 05:59 Go to previous messageGo to next message
check your air cleaner element?? that could be a cause.
Is there extrenal lekages?? defently a good idea to check out your cold start injector
what is the cars exhaust system like??? is there any leaks in the exhaust any blockages
It may also have incorrect fuel pressure: check your fuel pump out
[Updated on: Sun, 06 March 2005 06:01]
Toobs
Re: Need Help Camry drinking Fuel Sun, 06 March 2005 11:21 Go to previous messageGo to next message
It is also possible that there is a leak in your intake pipework... especially if the ECU uses an AFM to measure air.
The ECU will provide fuel for the amount of air which passes the AFM... now if some of this air is escaping before it gets to the engine your car will run rich and therefore burn more fuel than it needs.
Similarly if unmetered air is entering the engine the ECU will detect that the car is running lean (via the 02 sensor) and richen the mixture to keep the engine safe.
domasik
Re: Need Help Camry drinking Fuel Wed, 09 March 2005 06:18 Go to previous message
change ur fuel filter spark plugs air filter clean the throttle body and then see how it goes. changing the fuel filter made a huge differance on my camry when i swapped it for a new one if id done the plugs would have been even more of a differance too i reckon.
Previous Topic:JZ Side feed injectors
Next Topic:aw11s/c auto manual conversion
Current Time: Fri Oct 23 01:06:53 UTC 2026
Total time taken to generate the page: 0.042336940765381 seconds
