Toymods » Tech & Conversions » 4age rough idle
augo
Melb
January 2005
4age rough idle Sun, 06 March 2005 08:32 Go to next message
Gday I have a 16 valve age and it has a miss on idle,
also when you first punch the accelerator it misses as well.
Once you get past idle it runs tip top.
Someone told me it was an injector issue.
Help would be much appreciated.
FKN16V
NSW, East Coast
Re: 4age rough idle Sun, 06 March 2005 08:44 Go to previous message
Either timing is off a little or you've got spark plug trouble.
Injectors trouble at low rpm doesnt really make sense, if there was trouble with the injectors wouldnt it be more noticable up high in the rpm or under load, where good fuel delivery is needed.
Ive had this delima before, gap your spark plugs at 1.0mm and see how you go, might even pay to get decent new ones.
Also check for air in the cooling system, put the car on a big hill facing upwoods and open radiator cap, if there is any air in there it will escape.
Start with these and get back to us.
P.S might also be the dizzy bearing is on the way out.
Previous Topic:T25 Turbo flange dimensions
Next Topic:Diff questions
Current Time: Sat Oct 31 03:56:13 UTC 2026
Total time taken to generate the page: 0.0040748119354248 seconds
