Toymods » Tech & Conversions » 7MGE & 7MGTE AUTO Box Differences?
Mr.TRIM
7MGE & 7MGTE AUTO Box Differences? Sun, 06 March 2005 14:41 Go to next message
I`m wondering is there differences between 7mge auto box from Cressida & 7mgte auto box from MA 70 Supra.
Ples let me know ASAP.
Allan
Re: 7MGE & 7MGTE AUTO Box Differences? Sun, 06 March 2005 21:14 Go to previous messageGo to next message
yes the gte auto has a few more clutchs
MS-75
Re: 7MGE & 7MGTE AUTO Box Differences? Mon, 07 March 2005 01:49 Go to previous message
When I had my A340 done by MV, it turned out to be a cressida box actually.
From memory, the major differences are (and virtually only I think-mechanically anyway-ecu control is a different beast obviously)
Large cavity accumulator pistons (the larger cavity takes longer to fill up with fluid and so slows/softens the changes a bit)-the supra ones are basically just a flat topped piston.
(the two are interchangeable)
Slightly smaller diameter clutch packs (i think that was it anyway), and again the relevant bits from a donor GTE box drop straight in.
I Mike didn't mention specifically if the smaller pack setup had less clutches-but if it does then the GTE has extra clutches AND more of them. Suffice to say the Poopra box has more area full stop.
That was pretty much it-When mike put it together he put the other bits in it and now it's same-same.
Input/output shafts, bearings, casing etc is all identical.
Sean
[Updated on: Mon, 07 March 2005 01:52]
Previous Topic:Crown + 800hp GT42 pics!!!
Next Topic:a symptom of idling struggles and running rich...
Current Time: Wed Oct 28 06:12:24 UTC 2026
Total time taken to generate the page: 0.0043599605560303 seconds
