Toymods » Tech & Conversions » W58 shifter sloppy
ViPeR_NiPPleX
VIC, Sth Frankston.
W58 shifter sloppy Mon, 07 March 2005 01:18 Go to next message
Hey all,
In my ma61, the gearstick is so slack that you can put it in gear and the stick nearly returns back to where it looks like its in neutral.
I was wondering how to fix the excessive slop. I wouldn't think it would be just the bushing at the bottom of the stick.
The box from what I can tell has had a hard time, a lot of the syncros are worn out.
Thanks, hopefully someone knows what is going on.
PS. Hopefully Norbie doesn't slap my ass with SEARCH... as I have checked the w58 faq section and searched with litte result Smile
Toobs
Re: W58 shifter sloppy Mon, 07 March 2005 01:41 Go to previous messageGo to next message
1. You would be amazed how sloppy they feel with a dead (or no) bushing.
2. Sometimes the pin that goes through the ball in the shifter can get bent and or broken too... that allows the shifter to twist as well as the normal north south east west movement.
3. The spring returns which cause the shifter to return to its central position often lose their punch and can make the shifter extremely easy to move east / west.
These problems are all pretty easy to fix and most parts are interchangable between toyota gearboxes.
Buy the bush new though as its only worth a few bucks from Toyota.
wilbo666
Have you checked the bushes....I think you'd be surprised how shagged they can get...
other than that there is a plate in the shifter stick assembly that has a slot in it that could be flogged out..
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: W58 shifter sloppy Mon, 07 March 2005 02:34 Go to previous messageGo to next message
It'd be the bushes. The part numbers are around... You just need to search!! Laughing
I used to have them in my iPaq, but then I lost the memory card. Sad
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: W58 shifter sloppy Mon, 07 March 2005 03:32 Go to previous messageGo to next message
Thanks guys... hmm, well i'll definately get a bushing and let you all know how big a difference it made Smile
James
Dirty_Sanchez
Re: W58 shifter sloppy Mon, 07 March 2005 03:36 Go to previous messageGo to next message
Green Bush = PN# 33505-35020 $??
White Bush = PN# 33548-31010 $8
hope that helps
YelloRolla
On your mum!
Re: W58 shifter sloppy Mon, 07 March 2005 06:44 Go to previous messageGo to next message
It is not reduced to the one nylon ball bush at the base of the shifter, there is another bush which presses into the corresponding selector gizmo - my car used to wear out the ball bush because the onther one was excessively worn - I replaced both and now it is good (been a year since I fixed it).
Nark
Cabramatta, NSW
Re: W58 shifter sloppy Mon, 07 March 2005 07:23 Go to previous messageGo to next message
Yup.
The white bush referred to above is the one at the bottom of the shifter.
The green bush is the big one that positions the shifter in the cradle.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: W58 shifter sloppy Mon, 07 March 2005 07:43 Go to previous messageGo to next message
I was actually wondering about that... I had a quick read thru the w58 faq thread, I gathered that the white bush sits in the green bush??
Gimme a few hours, i'll pull it out and find a camera Smile
Nark
Cabramatta, NSW
Re: W58 shifter sloppy Mon, 07 March 2005 07:47 Go to previous messageGo to next message
Nah. The white bush attaches to the bottom of the gear stick.
The middle bulgy bit of the gear stick sits on the green bush...
It'll make sense when you pull it all apart.
wilbo666
Re: W58 shifter sloppy Mon, 07 March 2005 07:52 Go to previous messageGo to next message
ViPeR_NiPPleX wrote on Mon, 07 March 2005 18:43
WRONG! lol
The white bush "pop's" onto the end of the shifter.
The green bush sits in the uppermost section of the gearbox (the shifter position), the gear shifter (the thing you use to change gears Razz) seats into the green bush.
Your right when you get it apart you'll see whats going on Wink
purple_people_eater_1
Hobart, Tasmania
Re: W58 shifter sloppy Mon, 07 March 2005 08:33 Go to previous messageGo to next message
would lack of the green bush and the white bush in a W55 gear box
make it hard to find the gates if any?
I cant find any gears just walls where the gate should be.
I have found what appears to be neutral.
[Updated on: Mon, 07 March 2005 08:34]
Nark
Cabramatta, NSW
Re: W58 shifter sloppy Mon, 07 March 2005 08:35 Go to previous messageGo to next message
When my green bush was shagged, I had to twist the gear stick a certain way before it would get into any gear apart from 3rd & 4th.
BlackSupra
Re: W58 shifter sloppy Mon, 07 March 2005 08:45 Go to previous messageGo to next message
I think everyone has overlooked Jason's comments.
You can replace the green and white bushes till your heart's content but the damn thing will still be sloppy.
You need to pull off the shifter housing and int he extention housing there is a small arm with a bushed pressed into it.
The gearbox needs to be removed from the car, oil drained and the rear casing removed to get this extention arm off.
Once off, take to a machinist to press out old flogged bush and press in a new one, around a new white bush.
I have just done this and its UBER tight.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: W58 shifter sloppy Mon, 07 March 2005 10:52 Go to previous messageGo to next message
BlackSupra - You are absolutely right.
I pulled my 'short' stick outta my ra60 and put it in the supra. When I pulled out the supra stick... there wasn't any white bush on at all! So yeah, just got back from testing it out. The difference is major! But there is still a bit of slop in and out of gears...
First step is to replace white/green bushing. When I have time to yank out the gearbox, ill be getting a new bushing pressed in.
YelloRolla
On your mum!
Re: W58 shifter sloppy Mon, 07 March 2005 11:55 Go to previous messageGo to next message
BlackSupra wrote on Mon, 07 March 2005 19:45
You can be my wing man anytime!
Nolan
Campbelltown, NSW
Re: W58 shifter sloppy Mon, 07 March 2005 11:56 Go to previous messageGo to next message
Dirty_Sanchez wrote on Mon, 07 March 2005 14:36
hope that helps
what about george bush?
NOLAN
YelloRolla
On your mum!
Re: W58 shifter sloppy Mon, 07 March 2005 12:04 Go to previous messageGo to next message
Nolan wrote on Mon, 07 March 2005 22:56
hope that helps
NOLAN
Yes - part no = fux$7ick. Serves no real function to the tightening of things though.
Nark
Cabramatta, NSW
Re: W58 shifter sloppy Mon, 07 March 2005 12:11 Go to previous messageGo to next message
But when it's loose, a whole heap of things will fuck up...
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: W58 shifter sloppy Mon, 07 March 2005 12:20 Go to previous message
hehehe, loose bush... watch out!
Previous Topic:ke70 size of tunnels
Next Topic:Crank scraper Vs windage tray
Current Time: Fri Oct 23 23:59:09 UTC 2026
Total time taken to generate the page: 0.0066900253295898 seconds
