Toymods » Tech & Conversions » removing locknuts without a key
rb20det
removing locknuts without a key Mon, 07 March 2005 05:51 Go to next message
trying to get my wheels off to change brake pads and i cant get my lock nuts off because i have misplaced the key Embarassed they are external ones . i got 2 off with a socket but i rounded the ends on the socket (was old and cant get another one) was told to use a tapered socket but cant find one big enuf. i need help. pm me if you dont want everone to know how to get them off.
YelloRolla
On your mum!
Re: removing locknuts without a key Mon, 07 March 2005 06:30 Go to previous messageGo to next message
There are a number of ways to skin this cat
1) Use a hammer and a cold chisel - the chisel should be sharpened at a wide angle and be biased to one side. Hit the nut in the 'undo' direction.
2) Use some stilsons (aka pipe wrench or monkey wrench).
3) Grind some flats onto the nut and use your favorite shifter/socket/open ended spanner
4) weld a bolt to the nut and just undo it.
When you get thinking this is not that big of a deal.
Fattony
Re: removing locknuts without a key Mon, 07 March 2005 06:37 Go to previous messageGo to next message
Haha YelloRolla didnt think there was so many ways of doing it, i will keep it all in mind for the future incase i loose my lock nut. Denends on your rim ive been able to get a set of vice grips onto the lock nut and have been able to loosen it that way, though depdends if your rim allows you to get into that part.
Re: removing locknuts without a key Mon, 07 March 2005 07:16 Go to previous messageGo to next message
5) Bash a cheap socket that is a snug fit on to the lock nut. Undo.
rb20det
Re: removing locknuts without a key Mon, 07 March 2005 07:39 Go to previous messageGo to next message
chisel/monkey wrench/grinding wont work as they are set into the rim. it will also make welding anything onto it without stuffing the wheels imposible (wheels are simmons cost 2500) ill go past supercheap and buy a quality socket tommorow
beterthenu
Dubbo NSW
Re: removing locknuts without a key Mon, 07 March 2005 07:55 Go to previous messageGo to next message
remember the old demtel adds with the universal socket. that crappy socket with all the moving pins. works great.
arasta
brisvegas
Re: removing locknuts without a key Mon, 07 March 2005 08:56 Go to previous messageGo to next message
bro had this problem with his mr2/ turns out (at least with the bloke he used - tyrepower in morningside brissy) a lot of workshops will have an old socket they use for this purpose - whack it on the rattle gun and away they go at the locknuts.
charge you a few bucks (in his case hed had tyres done so they did it for free) for the job, and takes em all of a few minutes id imagine. usually they'll use a dead socket thats useless to them so its not a biggie.
or any of the previous methods
nabs478
Re: removing locknuts without a key Mon, 07 March 2005 09:12 Go to previous messageGo to next message
I did it by welding, You dont have to weld on a very big bolt, and oyu dont have to weld it very much. I managed to get a few of with some reasonably weak welds. Just find a mate who is good at welding
rb20det
Re: removing locknuts without a key Tue, 08 March 2005 13:12 Go to previous messageGo to next message
did it! ill tell u how . used a metal adhesive inside an old socket that almost fit the lock nut and pushed the lock nut in place. now i dont even have to get new nuts easyier than welding Very Happy
Fattony
Re: removing locknuts without a key Tue, 08 March 2005 23:10 Go to previous messageGo to next message
beterthenu wrote on Mon, 07 March 2005 18:55
I found those sockets forsale at a BP on the Hume Hwy down Melb way, they call those crappy things Gator Grip
CLG
Perth, Western Australia
Re: removing locknuts without a key Wed, 09 March 2005 01:21 Go to previous messageGo to next message
gianttomato wrote on Mon, 07 March 2005 15:16
Yep, easiest and best option here - I did it the other week to a set of lock nuts.
gold28
Madrid - Spain
Re: removing locknuts without a key Fri, 11 March 2005 02:43 Go to previous message
CLG wrote on Wed, 09 March 2005 12:21
I'll third that. Easiest way and it works.
Grab a socket and bash it onto the nut with a big hammer. Normally the sockets are a lot harder than the lock nuts, so they will cut a hex into it. Just go easy undoing the nut otherwise you will just strip your new found hex.
then throw away lock nuts, replace with normal nuts and invest in a big dog to guard your wheels
Previous Topic:Changing springs with compressor
Next Topic:Strut tops and RCA'S Raised my ride hieght
Current Time: Tue Oct 20 04:55:07 UTC 2026
Total time taken to generate the page: 0.0054168701171875 seconds
