Toymods » Tech & Conversions » Removing gearbox rear seal
ta2272
icon2.gif  Removing gearbox rear seal Mon, 07 March 2005 12:50 Go to next message
Hey im talking about the seal which seals over the tailshaft, i have removed one of these prevously but i just wedged a screw driver in between the seal and the outer case and popped it out. is the way it should be done? or are there any other suggestions as this did not feel right, (it worked thougth)
Jason
Allan
Re: Removing gearbox rear seal Mon, 07 March 2005 13:04 Go to previous messageGo to next message
i have a hooked screwdriver that i use to hook the seal and then tap it out with a hammer or i just hammer a screwdriver into opperset sides of the seal this tends to colapse it and it falls out with only fatal damage to the seal
styler
Re: Removing gearbox rear seal Mon, 07 March 2005 23:10 Go to previous messageGo to next message
dont molest it with a screwdriver, tap it out properly - you will have to make a tap (easy), then you wont score the housing.
use a thick piece of wire and make a hook on one end, overbend
it a tiny bit, then make a stopper on the other end and put
a heavy weight inbetween, eg a 1/4 pound hammer head. tap it
evenly and a few times, then its out.
then press in the new seal with wd40 and your fingers or tap
it in with a suitable socket.
if you tap it then all you have to do is drain the oil
and the remove tailshaft which is less work.
ta2272
Re: Removing gearbox rear seal Tue, 08 March 2005 06:53 Go to previous messageGo to next message
i wont need to drain the gearbox oil to do this would i?
Jason
styler
Re: Removing gearbox rear seal Tue, 08 March 2005 08:28 Go to previous message
yes unless you want to end up covered in gearbox oil,
remember you are removing the tailshaft which leaves a
gaping hole in a gearbox full of oil Smile
also buy some new oil valvoline from supercheap $30, you
should never reuse oil, it will have bits of metal and
dirt in it.
Previous Topic:Help! (5e-fhe) Toyota Sera choking
Next Topic:Camber Kit for MA70?
Current Time: Wed Oct 28 00:40:16 UTC 2026
Total time taken to generate the page: 0.016043901443481 seconds
