Toymods » Tech & Conversions » 2x 4age oil coolers?
rthy
Melbourne - NthSubs
2x 4age oil coolers? Mon, 07 March 2005 14:24 Go to next message
how much difference if i got 2 stock oil coolers or a bigger oil cooler for a 4age? am i wasting my time or is it worth while?
Re: 2x 4age oil coolers? Mon, 07 March 2005 22:52 Go to previous message
that depends on your oil temps. if they get excessive then you will need a better cooler. you can also use a bigger cooler with an oil thermostat to control the temps...
if you are just using bypass type, then maybe not as much point. more efficient (at cooling) to go with full flow cooler, but means you need less pressure drop and higher flow potential.
maybe run two stock coolers in parallel?
or just bite the bullet, spend $200 and get a good setrab/serck/etc cooler with bigger fittings..
jmho Wink
Previous Topic:2ZZGE gearbox
Next Topic:Levin grills need help
Current Time: Sat Oct 31 13:02:57 UTC 2026
Total time taken to generate the page: 0.39201188087463 seconds
