Toymods » Tech & Conversions » surge tank fuel pump wiring
fade-e
surge tank fuel pump wiring Mon, 07 March 2005 14:46 Go to next message
hey guys, yes i searched and i already know how to hook it all up but the exact wiring of the fuel pumps is what i want to know.
SOOOOOOOO i wanna know how people have wired their lift and HP pumps?
iv been told to wir them together and off to the ECU (Haltech F9) but should they be wired in series or parrallel????
or should they be wired seperately???
gabe
Re: surge tank fuel pump wiring Mon, 07 March 2005 14:55 Go to previous messageGo to next message
If you wire them in series, the supply voltage will be dropped across the 2 pumps.
ie. if you have 2 identical pumps and a supply of 12V, each pump only gets 6 V.
Wire them in parallel and each pump gets a full 12V.
Gabe
fade-e
Re: surge tank fuel pump wiring Mon, 07 March 2005 15:20 Go to previous messageGo to next message
thanks gabe. it doesnt matter that ones a pierburg 8psi pump and the opther is a VL turbo pump?
my main concern is that it is controlled by the ECU and therefore if it needs more fuel then both will flow more and therefore im worried that the lift pump will over load or am i just too worried for nothing?
thanks again
RouwT
holland
Re: surge tank fuel pump wiring Mon, 07 March 2005 15:27 Go to previous messageGo to next message
If you're worried about the surge tank being overfilled, just get a return line from the Surge tank to the main tank , this way You're also getting al the air out of the surge tank, which is good anyway.
get the pump parralel, and at leat the Injection pump controlled by the ECU, the feed pump to the surge tank can be just Ign/on=12v. with or without a tail safe switch in between, so it shuts off dureing an acciedent.
or weld a sugre pot under your tank like this
http://venixjr.student.utwente.nl/thomas/gallery/v iew_photo.php?set_albumName=album14&id=DSCF010 1
http://venixjr.student.utwente.nl/thomas/gallery/v iew_photo.php?set_albumName=album14&id=DSCF010 2
grtz thomas
[Updated on: Mon, 07 March 2005 15:30]
gabe
Re: surge tank fuel pump wiring Mon, 07 March 2005 15:28 Go to previous messageGo to next message
Yeah worried for nothing.
Obviously they are both 12V pumps so they need to be wired in parallel.
The pump will draw as much current as it needs. It will draw more current if it stuffed ie. short in the windings etc, or if you stall it somehow, like blocking it mechanically etc. (use a filter to protect your pumps)
If they are brand new pumps they should be fine.
Might be worth your while having the low pressure pump power up first to 'prime' your surge tank. Its bad to run a pump with no fuel running through it as some pumps use the petrol to cool the pump.
Use an aux output to drive your high pressure pump.
Just a suggestion....
Gabe
fade-e
Re: surge tank fuel pump wiring Mon, 07 March 2005 16:05 Go to previous messageGo to next message
thanks guys
takai
Re: surge tank fuel pump wiring Mon, 07 March 2005 22:31 Go to previous messageGo to next message
Aye, i run a Pierberg and a VL pump as well. Wired up nicely in parallel off my Haltech. Works fine.
fade-e
Re: surge tank fuel pump wiring Mon, 07 March 2005 23:18 Go to previous messageGo to next message
takai wrote on Tue, 08 March 2005 09:31
thats what i want to hear Very Happy good stuff
once again cheers guys
Re: surge tank fuel pump wiring Mon, 07 March 2005 23:58 Go to previous messageGo to next message
you are using relays for this? 10amps thru an ECU can't be a good thing for long ;P
takai
Re: surge tank fuel pump wiring Tue, 08 March 2005 00:03 Go to previous messageGo to next message
Surprised You think i wouldnt? The Haltech has its own relay for fueling.
Re: surge tank fuel pump wiring Tue, 08 March 2005 00:13 Go to previous messageGo to next message
sorry, that was meant to be a general "you" Wink
amd nice to have internal relays.. what are they rated to?
[Updated on: Tue, 08 March 2005 00:14]
fade-e
Re: surge tank fuel pump wiring Tue, 08 March 2005 10:38 Go to previous messageGo to next message
oldcorollas wrote on Tue, 08 March 2005 11:13
im not sure what they are rated to. i have the manual here but at the moment too lazy to check
takai
Re: surge tank fuel pump wiring Tue, 08 March 2005 11:50 Go to previous message
The E6X runs two external relays. One for the Fuel, and one for something else (cant quite remember)
Previous Topic:any sicko's interested in 5m-e's
Next Topic:'90 mr2 turbo and lsd
Current Time: Mon Oct 26 17:41:32 UTC 2026
Total time taken to generate the page: 0.038832902908325 seconds
