Toymods » Tech & Conversions » AW11 4AGE MR2 underheating
dr trim
adelaide
March 2005
AW11 4AGE MR2 underheating Tue, 08 March 2005 06:03 Go to next message
hey guys,
i have put a deposit on an AW11 4AGE mr2 and when i took it for a drive, the temperature guage took probably 10 minutes to rise above C on the temp guage and it barely went 1/4 up the guage, do i have a problem here? or is that normal?
when i turned the heater on the it didn't seem very warm at all, which makes me think the guage was reading true. Everything else with the car seems to be in order, maybe there's no thermostat in the housing (if they come seperate?) so the engine doesnt get a chance to warm up.
I do know that the mr2 has something like a 12 litre cooling system, but i didn't think it would be too efficient Confused
any info or experience would be appreciated.
-mike
4agte
Toronto, Downtown
Re: AW11 4AGE MR2 underheating Tue, 08 March 2005 07:13 Go to previous messageGo to next message
sounds like there is a air lock in the cooling system where someone has changed the coolent incorrectly or the thermostat is rooted.
If the thermostat is rooted it will stay open allowing the water to continually run through the block and then to the radiator meaning the engine will run really cool. Its a common problem in 4age's especially if some dingbat has used green coolant in it or mixed green coolant with red coolant.
Only use red coolant in 4age's.
4agte
Toronto, Downtown
the thermostats usually rust
._T_.
Re: AW11 4AGE MR2 underheating Tue, 08 March 2005 21:52 Go to previous messageGo to next message
ive had a number of aw11's come in with broken thermostats. only the aw11 for some reason has this problem - but the description is as per a failed (broken open) thermostat
T
IRA11Y
Club Member
Re: AW11 4AGE MR2 underheating Tue, 08 March 2005 21:56 Go to previous messageGo to next message
could also be a faulty sender, but id look at the thermostat first as well.
bootheman
in a box
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 01:17 Go to previous messageGo to next message
ahaha happend to mine!!!
dr trim
adelaide
March 2005
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 04:54 Go to previous messageGo to next message
IRA11Y wrote on Wed, 09 March 2005 08:26
well i thought about that, but logically if the heater seems to be barely hot then u'd think that the coolant running through it isn't warm enough for it to work properly. so i'd say the guage is on the money, and that the thermostat either isn't there or has been stuck open.
The AW11 seems to have a funny coolant system, how do i get the air ou of the system? what are the steps to letting all the coolant out and refilling it?
4agte
Toronto, Downtown
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 06:03 Go to previous messageGo to next message
dr trim wrote on Wed, 09 March 2005 15:54
its complicated but buy a haines manual and it will tell all. What i do when flushing the coolant is the run the engine untile hot then flush with the engine running leaving the heater on then once the water is clear turn off the hose start to put in coolant until the water comming out the radiator is red then turn the hose off and fill with coolant.
Id put my money on the thermostat its a common problem with all 4ag engines when run with green or no coolant at all.
toof
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 07:41 Go to previous messageGo to next message
to fill the coolant look at the radiator it gives a good run down on how to do it... else.
take off the under carrage lining and you will see two pipes for coolant. about where your feet sit you will find two 10mm bolts. whip them out and you will start getting poured in coolant.
there is also a block drain but it is conveniently located underneath your air conditioning compressor. (hence i couldnt be bothered)
drain the coolant from those drain points *theres a bit of it* then i blast it with the hose (drom the filler point) flush out any crap. then make sure its all drained. get the hose supplied (in the frunk next the the master cylinder behind the plastic lining.
then attach it to the connector on the radiator (top passenger side) and open the valve a few turns.
make sure you have all the drain bolts in. then ive always done it with the tail slightly jacked up, start filling until you get coolant coming up the hose. once it stabilies the level in the hose (attach it to the hood lining) then close the valve.
attach the hose to the similar attachment on the heater inlet. and again fill until it is coming up the hose. close.
then there is a third bleed point on the hose located above the gearbox. attach it to that and again contrinue filling until the hose has coolant in it. close the valve. keep filling until you can see coolant running up the hose into the overflow bottle. (or does it not have the external hose just straight to the bottle) cant remember it may just go straight to the bottle.
then top it up until it is full run the engine for a bit and top continue to top until she will take no more top up the overflow bottle (worth taking out and cleaning whilst your at it) and voila your done.
oh and remember to use toyota red coolant.. its the shit Razz
dr trim
adelaide
March 2005
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 08:34 Go to previous messageGo to next message
well i've bought the car from a toyota dealer (yes car yards suck, but parents know the owner so i got a reasonable price) u'd wanna hope they've put the right coolant in there.
also when i drove it, at sitting at 100kph, the car seemed to sort of.. shimmer, i read somewhere it can be the tyres done up too tightly, is this actually a problem? when i went down a steep hill at 100 and braked, the car would shudder, but under normal braking it was perfect..
hmm?
4agte
Toronto, Downtown
Re: AW11 4AGE MR2 underheating Wed, 09 March 2005 12:51 Go to previous messageGo to next message
sounds like warped rotors.
toyota may have put the right coolant in but the previous owners mechanic may not have for god knows how many years.
anyways would have paid to get a nrma inspection b4 buying.
dr trim
adelaide
March 2005
Re: AW11 4AGE MR2 underheating Thu, 10 March 2005 05:57 Go to previous messageGo to next message
well they are friends of mine, so i don't expect them to stooge me if something comes up. can't u just machine warped rotors? somehow it doesn't sound right..
4agte
Toronto, Downtown
Re: AW11 4AGE MR2 underheating Thu, 10 March 2005 06:45 Go to previous messageGo to next message
there are usually a couple of reasons why brakes vibrate under load.
warped discs
worn pads
wheel alignment
it may also be toe ball joints in an mr2 as they are usually gone.
i didnt mean they were trying to rip you off but getting a qualified mechanic to look the car over can give you an idea of what you will need to do to the car to get it running right.
I bought mine from a caryard aswell after a dodgy japanese man by the name of aki ran off with my deposit and refused to have the car inspected.
just didnt wanna get ripped off again
[Updated on: Thu, 10 March 2005 06:47]
ChunksNensja
Templestowe, Melbourne
January 2005
Re: AW11 4AGE MR2 underheating Thu, 10 March 2005 08:56 Go to previous message
4agte wrote on Tue, 08 March 2005 18:13
Stupid question, but why only red? Whats the difference?
Previous Topic:constantly wearing speedo gear
Next Topic:Oil cooler connection
Current Time: Fri Nov 20 05:18:34 UTC 2026
Total time taken to generate the page: 0.0069360733032227 seconds
