Toymods » Tech & Conversions » air-con probs
spans
air-con probs Tue, 08 March 2005 10:01 Go to next message
Hey all,
Just having a little prob with my air-con in my jza-70.
After using it, it will stop working (both cooling and heating). The light on the dash starts flicking on and off in both A/C mode and ECON mode. It does this at random intervals and I can't pin it to one cause.
Could it just possibly need to be regassed, or will the compressor be shagged and need replacing ? Opinions pls!
Luke
mick
toowoomba qld
Re: air-con probs Tue, 08 March 2005 11:53 Go to previous messageGo to next message
personally I think your compressor maybe on the way out. I had the same problem with the Camry. to check if your Air-conditioner unit needs regasing:-
There should be a sight glass above the reciver/dryer. start your car up with the Air- conditioner on and let it run for a few minutes and observe the flow of refrigerent through the sight glass. If there is a heap of bubbles flowing throw it means it is low. I must ask, Does it blow cold air at all when it's being used/ before it stops?
spans
Re: air-con probs Sun, 13 March 2005 12:32 Go to previous messageGo to next message
When it's being used, yes it does blow cold air or hot air or whatever I still use it for.
It functions perfectly, except when it cuts out and blows normal air!
Cyber-punk
Brisbane, QLD
Re: air-con probs Sun, 13 March 2005 20:51 Go to previous messageGo to next message
I'd do as mick suggested and check to see if you can see bubbles in your filter\dryer shells sight glass. Although that doesnt sound as if its the case
Perhaps you have a faulty switch somewhere, either the pressure switch on your AC compressor or a temp sensor.
Toobs
Re: air-con probs Mon, 14 March 2005 00:47 Go to previous messageGo to next message
The flashing A/C light simply means that a fault has been logged in the A/C ECU.
You need to bridge two terminals on the check connector to get it to spit out the code.
I don't remember which pins off the top of my head though Sad
Toobs
Re: air-con probs Mon, 14 March 2005 01:27 Go to previous message
Alldata says that a flashing A/C light can mean:
slipping compressor drive belt.
faulty revolution sensor.
or faulty A/C amplifier.
Previous Topic:1GGTE - dimensions
Next Topic:goo to attach windscreens?
Current Time: Wed Nov 4 09:52:24 UTC 2026
Total time taken to generate the page: 0.078767061233521 seconds
