Toymods » Tech & Conversions » 4agte using stock ecu
d-shiznit
W.A
icon5.gif  4agte using stock ecu Tue, 08 March 2005 10:57 Go to next message
Hey ppl!
I have an ae92 smallport map sensored 4agze.
I know that I can use the stock ecu to run the engine with a turbo up to 14psi, but my question is:
Can I change to the bigport head and NA bigport cams and still use the stock ecu?
Anyone running this setup?
Thanks!
shinybluesteel
melbourne
Re: 4agte using stock ecu Tue, 08 March 2005 11:53 Go to previous messageGo to next message
probably
4agte
Toronto, Downtown
Re: 4agte using stock ecu Tue, 08 March 2005 12:28 Go to previous messageGo to next message
cam timing duration and lift would all be different i would use atleast a piggy back ecu.
You could use it but y not use the smallport
are you sure those ecu's are mapped to 14psi i thought they were only mapped to 12psi in the later versions. I defiantley know the afm ecu is mapped to 14psi.
d-shiznit
W.A
Re: 4agte using stock ecu Tue, 08 March 2005 12:34 Go to previous messageGo to next message
I want to use the bigport head as it's supposed to be better for turbo applications... Also I already have a rwd bigport inlet manifoild.
4agte - Yup my mate runs his ae92 map sensored 4agte to 14psi using the stock ecu. No problems.
4agte
Toronto, Downtown
Re: 4agte using stock ecu Tue, 08 March 2005 12:41 Go to previous messageGo to next message
fair enuf and i agree the bigport engines are better for turbo applications i will be turboing my 4agze afm version very shortly.
The smallport ecu should work "ok" with the bigport head.
Re: 4agte using stock ecu Tue, 08 March 2005 12:48 Go to previous messageGo to next message
bigport = better for high kw applications.
smallport better for driveability and medium kw applications?
the bigport ports are very large.
monkeymajik
Re: 4agte using stock ecu Tue, 08 March 2005 14:51 Go to previous messageGo to next message
The afm ecu is mapped higher than 14psi. I am running one at 16psi right now, with no FCD or anything.
takai
Re: 4agte using stock ecu Tue, 08 March 2005 22:59 Go to previous messageGo to next message
I have the smallport ecu working with bigport cams. Not hard at all.
d-shiznit
W.A
Re: 4agte using stock ecu Tue, 08 March 2005 23:33 Go to previous message
Takai - What does it drive like? Is it rough at all?
Previous Topic:Wheel to Guard gap difference at front - Help needed
Next Topic:Elements of turbocharging a 4k in a KE10
Current Time: Sat Oct 24 15:15:43 UTC 2026
Total time taken to generate the page: 0.0051190853118896 seconds
