Toymods » Tech & Conversions » GZ help a very tough question
rolla kid
Brisbane (AUS)
GZ help a very tough question Tue, 08 March 2005 11:41 Go to next message
Hey guys my gz wont rev out it hits about 5500rpm on any gear and its like it hits a rev limeter it just wont go any further. i just had my injectors cleaned they are all good new spark plugs it has a 7mgte fule pump with bigger 4age fuel line it has a 2 core raditor i dont think it is heat related casue it does it with the bonnet off the only error code it shows is 51 (switch signal) i think i have not yet checked the compression put in the works on doin that i just cant find a problem i have read stuff about people sayin it is the map sensored ecu's for the gz can anyone verifie this or knows anyhing about it i really need help on it
[Updated on: Tue, 08 March 2005 11:42]
DiZ_
The Eastwood MASSIVE !
Re: GZ help a very tough question Tue, 08 March 2005 12:46 Go to previous messageGo to next message
Seen one that did the same, the ECU was cutting the supercharger off at over ~5500RPM , there is a pinout on the ECU for a LED to indicate that the charger is engaged , might wanna look at that first.
4agte
Toronto, Downtown
Re: GZ help a very tough question Tue, 08 March 2005 13:12 Go to previous messageGo to next message
rolla kid wrote on Tue, 08 March 2005 22:41
If its the map sensored version of the 4agze then it wont have an air flow meter (a decents sized black and silver thing thats attached to the inlet pipe after your air filter)
error code 51 has to do with the air conditioning.
common cause
Displayed when A/C is on when TE1 and E1 connected in test mode
I would say it has to do with something else.
I doubt it would be compression related as then the car would just be sluggish and with boost it would rev past 5k.
Sounds to me like an electical problem.
4agte
Toronto, Downtown
Re: GZ help a very tough question Tue, 08 March 2005 13:13 Go to previous messageGo to next message
DiZ_ wrote on Tue, 08 March 2005 23:46
i doubt this has anything to do with it i run my gze without anything connected to the pinout for the supercharger light and it runs fine revs to the rev limiter every day of the week
DiZ_
Re: GZ help a very tough question Tue, 08 March 2005 13:16 Go to previous messageGo to next message
4agte wrote on Wed, 09 March 2005 00:13
The pinout doesnt have to be connected to run properly , its just a good diagnosis tool if his ECU is kicknig off the clutch at high revs for what ever reason.
[Updated on: Tue, 08 March 2005 13:17]
Darola
Taree, 4h nth of syd
Re: GZ help a very tough question Tue, 08 March 2005 23:45 Go to previous messageGo to next message
Hey there mate, when r u testing this problem?????
mine does exactly the same problem when it is cold and has just been started. it will fuel cut at 5500rpm, after driving for 5-10min it is fine, even if i have been driving all night then stop to get fuel it will do it again.
my mate from nz said this is normal for the gze to do.
hope this helps
Eddie
(Darola)
rolla kid
Brisbane (AUS)
Re: GZ help a very tough question Wed, 09 March 2005 06:15 Go to previous messageGo to next message
do you mean the little led on the instrument cluster??
rolla kid
Brisbane (AUS)
Re: GZ help a very tough question Wed, 09 March 2005 06:18 Go to previous messageGo to next message
It does it all the time someone told me the ecu's for the map versions are ment to be shit i tested the pulse to the injectors and there is pulse goin to them i just cant workout wat it could be
irishtwincam
Ireland
Re: GZ help a very tough question Wed, 09 March 2005 13:09 Go to previous messageGo to next message
http://forums.club4ag.com/topic.asp?TOPIC_ID=94398
http://www.mr2oc.com/showthread.php?p=893653#post8 93653
Its timing being pulled.
Happened in amtes corolla with ae101 gze.
If the cars is idling for a while, it happens.
Pull over, wait for light to go, then floor it again.
http://www.my-acoustic.com/Car/ECU/ECUskleow/ECUsk leow.htm
Possible solution.
Oh If only I had money to play with.
rolla kid
Brisbane (AUS)
Re: GZ help a very tough question Thu, 10 March 2005 06:20 Go to previous messageGo to next message
Dude it does it all the time if i start it in my garage and try to rev it up it wont rev past same with driving
4agte
Toronto, Downtown
Re: GZ help a very tough question Thu, 10 March 2005 07:13 Go to previous messageGo to next message
DiZ_ wrote on Wed, 09 March 2005 00:16
the engine would still rev tho
Adsport
Perth WA
Re: GZ help a very tough question Sat, 12 March 2005 09:40 Go to previous message
could be a cooler piping leak, pinhole or cracked silicone join.
Previous Topic:clutch for a AE101 4AGZE
Next Topic:torque converter lockup
Current Time: Fri Nov 20 08:46:24 UTC 2026
Total time taken to generate the page: 0.0083270072937012 seconds
