Classifieds » Parts Wanted » Early Corolla Parts Needed
rollin_stock
February 2005
Early Corolla Parts Needed Tue, 08 March 2005 14:48 Go to next message
Hi there, i am looking for a few things; only in good condition please
KE10 68' (Later model) Radio Blanking Plate
Early Corolla Momo Steering Wheel Boss
2x 14" x 7 110x4pcd Hotwires or other same period mags FOUND
4x40mm DHLA Dellorto extremely short ram tubes 10-15mm FOUND
2x 40mm DHLA Dellorto rebuild kits
KE10 Drivers side door hinges
KE10 Bonnet Chrome Strip
KE10 68' Uncracked grille badge
Cheers Sean
0432 909 790
or rollin_stock@yahoo.com.au
Any one in Adelaide with a KE20 they want to throw away, i need your front crossmember before you do!!
[Updated on: Tue, 29 March 2005 12:16]
PMP020
January 2005
Re: KE10 Parts and Dellorto Carb Parts Wed, 09 March 2005 07:33 Go to previous messageGo to next message
hey sean all o can help you wit is.
info on putting ke20 front cross memba in i know a dood who already looked into it and if u down with some cutting and welding and drilling and TIME it can work but ull hav 2 do ur own mods.
electonic dizzy well if u find 1 of them please make sure there is 2 otherwise i will get quite shitty.
ur window rubbers go 2 rare spares at richmond on south rd.
all panels n parts iw ood suggest takinf the time 2 get 2 just wrecking toyota at wingfield and hava GOOD look around they got alot of stuff that even they dnt no they have. all tho they charge top dollar 4 good stuff.
or just wrecking jap at holden hill they hava lot 2 do with toyoland so u mite get lucky.
hope dat helps ya out abit.
catchya scott
rollin_stock
February 2005
Re: KE10 Parts and Dellorto Carb Parts Wed, 09 March 2005 07:52 Go to previous messageGo to next message
Cheers Scott,
might go for a drive tomorow, will check out dizzys too
Sean
rollin_stock
February 2005
Re: KE10 Parts and Dellorto Carb Parts Fri, 11 March 2005 06:36 Go to previous messageGo to next message
BUMPEROO!
Re: KE10 Parts and Dellorto Carb Parts Sat, 12 March 2005 10:44 Go to previous messageGo to next message
rollin_stock wrote on Wed, 09 March 2005 01:48
KE10 Radio Blanking Plate,
Info on putting KE20 front crossmember in car,
KE10 Front 1/4 window rubbers
Cheers Sean
0432 909 790
early or late blanking plate.
KE10 bolta are 28" apart, KE20 is 28.5" apart, and KE20 are spaced 1" wider apart on same side.
will need radius rod mounts.
i have some KE10 lower arms with KE20 steering arms ont hem Wink
front 1/4 rubbers.. good luck Wink we should do a GB on them.. actually, ask Pro-Ke
door hinges are all rooted, get one bronze bushed.
rollin_stock
February 2005
Re: KE10 Parts and Dellorto Carb Parts Mon, 14 March 2005 07:14 Go to previous messageGo to next message
Stewart PM Sent
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Tue, 15 March 2005 12:41 Go to previous messageGo to next message
BUMP
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Wed, 16 March 2005 11:32 Go to previous messageGo to next message
BUMP (do i have a limited number of these?)
Evil or Very Mad
BUMP
BUMP
BUMP
BUMP
BUMP
BUMP
BUMP
BUMP
BUMP
BUMP
Re: KE10 Parts and Dellorto and Mags 110x4pcd Wed, 16 March 2005 11:34 Go to previous messageGo to next message
KE10 Uncracked grille badge (red or green not fussed!)
you knoe there are other colours Wink such as blue and white Razz
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Wed, 16 March 2005 12:18 Go to previous messageGo to next message
Stewart,
no i didnt, learning all the time, many thanks master! Very Happy
btw pro-ke said to get the 1/4 window rubbers for peter jacksons rubber in vic.
Sean
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Fri, 18 March 2005 05:37 Go to previous messageGo to next message
BUMP
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Mon, 21 March 2005 09:37 Go to previous messageGo to next message
B Razz U Laughing M Surprised P Rolling Eyes
rollin_stock
February 2005
Re: KE10 Parts and Dellorto and Mags 110x4pcd Wed, 23 March 2005 07:41 Go to previous message
B Sad U Confused M Rolling Eyes P Very Happy
Previous Topic:wtd: ECU plug for 20v
Next Topic:WTB: TRUENO PARTSS!!!!!!
Current Time: Fri Nov 20 18:54:25 UTC 2026
Total time taken to generate the page: 0.011696100234985 seconds
