Toymods » Tech & Conversions » mr2 3sge gearbox or 3sgte gearbox?
mush
icon10.gif  mr2 3sge gearbox or 3sgte gearbox? Tue, 05 November 2002 09:05 Go to next message
i am putting a 3sgte engine ito my 93 mr2 (3sge), but i have a lsd wth my current gearbox and the turbo 1 is non lsd, could i run the turbo engine with the original box ? or should i get a turbo lsd, and if so were from and how much ?
._T_.
Re: mr2 3sge gearbox or 3sgte gearbox? Tue, 05 November 2002 22:08 Go to previous messageGo to next message
n/a box will die if you run the turbo motor. best option is to source an lsd either from japan (second-hand) or possible via NZ - i may be able to help you out.
new lsd will set you back about $1200-1800
how are you sure you have a factory lsd with your n/a box by the way? i had a look at an aussie gt rrecently which the owner was certain had an lsd - but it did not.
T
jase
Re: mr2 3sge gearbox or 3sgte gearbox? Tue, 05 November 2002 23:23 Go to previous messageGo to next message
The syncro's are pretty crap in the early turbo boxes.
Without LSD an MR2 still has considerably more traction than many other cars, so whilst it would obviously be better with the LSD, don't think it will be crap without.
It is this great traction that is the main reasons the gearboxes die. (or abuse)
I have often thought that if you had both boxes side by side, you could see if the lsd was interchangable, best way may be to start by seeing if aftermarket available lsd's share common part numbers, and if so try to swap yours. I really don't know how that would go though.
._T_.
Re: mr2 3sge gearbox or 3sgte gearbox? Tue, 05 November 2002 23:47 Go to previous messageGo to next message
s and e series lsd units will not interchange -i can tell you that!
good synthetic oil does wonders for any transaxle too (castrol syntrans)
T
._T_.
Re: mr2 3sge gearbox or 3sgte gearbox? Wed, 06 November 2002 02:08 Go to previous message
"japandy" on e-bay has a sw20 gt lsd for sale right now (he seems to get them all the time) unit has apparently had 1 month of use.
bidding was at ~$US100 when i looked.
T
Previous Topic:MAP Sensors and Airflow meters.
Next Topic:ta22
Current Time: Mon Jun 15 05:42:03 UTC 2026
Total time taken to generate the page: 0.004256010055542 seconds
