Toymods » Tech & Conversions » Rack mounted with no rubbers
Rack mounted with no rubbers Wed, 09 March 2005 01:25 Go to next message
Hello, has anyone driven a car with a steering rack mounted with no rubber between the rack and the mounts on the xmember?
Wondering if this would cause the feedback to be too harsh or not.
Joel
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Rack mounted with no rubbers Wed, 09 March 2005 01:27 Go to previous messageGo to next message
what do you propose to put in its place? urathane? alloy?
Re: Rack mounted with no rubbers Wed, 09 March 2005 03:02 Go to previous messageGo to next message
Custom mounts will be made for both the xmember and rack itself if I took this path. So probably a alloy or steel mount would be holding the rack to the xmember.
Re: Rack mounted with no rubbers Wed, 09 March 2005 03:21 Go to previous messageGo to next message
You will feel every little bump on the road through the steering wheel.
Re: Rack mounted with no rubbers Wed, 09 March 2005 03:39 Go to previous messageGo to next message
Cool thats the answer I was after.. In that case I think i'll keep it mounted in the urathane.
TA-022
Glenmore Park, NSW
Re: Rack mounted with no rubbers Wed, 09 March 2005 10:07 Go to previous messageGo to next message
so basically you have a plate off the xmember to mount the rack...
then a rubber/urethane chunk/rectangle etc...
then the rack ontop of this...with bolts running through all three?
Nathan
Re: Rack mounted with no rubbers Wed, 09 March 2005 10:18 Go to previous messageGo to next message
Yeah I got a plate off the xmember,
the passenger side of the rack is round and I have a rubber mount off a holden astra i think that has the right diameter hole in the centre for the rack and it has a flat base.
then on the driver side I use the original ke70 rubber mount as that already has a flat bottom.
the rack is spaced up 6mm for correct height.
then i have holden astra & hmm another car cannot remember metal brackets over the mounts they are like a complete loop down to the base (unlike the ke70/ae86 brackets that are a very low profile). then bolts through the brackets, through the plate with nuts on the bottom.
C
Re: Rack mounted with no rubbers Wed, 09 March 2005 10:20 Go to previous messageGo to next message
i'd be worried about the constant rattling causing wear and damage to both the mount and the rack... you may need to bolt it a bit too firmly to hold if it's solid too.. whereas with some compliance, everything is nicer Smile... you don't have to have thick urethane Wink
allencr
tallahassee FL usOFa
Re: Rack mounted with no rubbers Wed, 09 March 2005 16:58 Go to previous message
steering boxes are all solid mount, and the idler is solid on a few, so i wouldn't worry that much.
all race cars are solid!
Citroen racks(ID, DS & SM) are solid mount, and the only rubber bushing in the entire steering & suspension is a very small one on the inner tie rod to rack joint. all suspension arm joints are tapered roller bearings, even on a 2CV.
Previous Topic:7MGTE CT26 turbine/exhaust wheel diameter?
Next Topic:gze alternator
Current Time: Thu Oct 15 17:49:09 UTC 2026
Total time taken to generate the page: 0.084272146224976 seconds
