Toymods » Tech & Conversions » Boost gauges. Please educate an ignorant old man.
Farkurnell
Liverpool
February 2005
Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:04 Go to next message
I've got a boost gauge in the RA28 plus I've got a spare that came in a box of bits. The first one reads from negative 100 through to 150 kPa. The other one reads from 0 to 700 kPa.
My question is.....WHAT DOES IT ALL MEAN????
The first one's needle indicates from the negative numbers through to the positive numbers depending on how much I accelerate (obviously). The second one (which I tried today) sits on zero and won't move till the boost is up.
Why is there a difference in the calibrations (is that the right word?) of the two? Which is betterer?
They are both VDO gauges.
Please excuse my ignorance on these matters.
Cheers, Greg.
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:33 Go to previous messageGo to next message
What you have here are a pair of relative pressuge guages, with differing pressure ranges.
The one which shows a negative thru to positive range, allows the guage to show manifold VACUUM as well as manifold PRESSURE (relative to atmospheric pressure). To me this is the better type to use, as it gives good idications of how your engine is behaving in off-boost conditions, and can help identify manifold leaks should they appear.
The other guage is a positive relative pressure guage, showing only pressure ABOVE atmospheric pressure (aka, BOOST). This means that unless your turbo is pushing through enough air to increase manifold pressure above atmospheric pressure, the guage will not register any reading.
Most likely, due to the range, this guage is intended for very high boost engines in race use, or possibly not even for small engines at all!!
700kPa = ~7.0bar or 102.9psi!!!
150kPa = 1.5bar or around 22psi - this makes much more sense to use!!
i hope this helps matey Smiley =
Well one is reading only boost , and the other is reading vacuum and boost.
[Updated on: Wed, 09 March 2005 05:40]
Kyosho
Wollongong
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:36 Go to previous messageGo to next message
The boost guage that reads into the negative is a boost/vacuum guage...
They are good...
They allow you to know what the pressure is compared to the air...
The needle will read into the negative in Hg/cm^3 where as boost is measured in kPA...
The second one can not read vacuum...
The one that reads vacuum I'd find better as you can see when boost is about to hit...
Dirty_Sanchez
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:47 Go to previous messageGo to next message
a gauge that reads 102.9psi?
DANGER TO TEH MANIFOLD!!!1!11
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:49 Go to previous messageGo to next message
kyosho,
it is not necessarily so that his guage reads mercury levels as the units of vacuum.
mmHg is simply another unit of pressure measurement. It is very common so see mmHg on boost/vacuum guages as this is the industry standard for manifold vacuum measurements.
Personally i think pressure guages should all be reading absolute pressure......
Farkurnell
Liverpool
February 2005
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 05:51 Go to previous messageGo to next message
Great stuff you blokes. Much appreciated. I knew I came to the right place for info.
Cheers, Greg
ke35 - 4AGZE
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 06:41 Go to previous messageGo to next message
why do you want to read absolute??
100kPa - atmospheric pressure or 0 on common gauges
so u want ur gauge to read 100 kPa with the engine off and >100 on boost and <100kPA with manifold vacuum..
Razz
[Updated on: Wed, 09 March 2005 06:41]
Kyosho
Wollongong
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 07:01 Go to previous messageGo to next message
THE WITZL wrote on Wed, 09 March 2005 16:49
kyosho,
The mmHg is GENERALLY used as it gives a greater MOVEMENT on the needle then what kPA would...
EVOSTi
cambo
      no
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 10:33 Go to previous messageGo to next message
yeah i dont think you would want an absolute pressure gauge in a car, no point, just adds confusion.
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 11:15 Go to previous messageGo to next message
i totally agree... if you are tuning an EFI system, usign absolute pressure make a whole mot more sense from the fuelling calculation side.
i would much prefer to have an absolute pressure gauge Smile
as for mmhg.. US archaic dinosaur units. SI is the way to go Razz
and the total needle movement depends on what the gauge is rated to, not the units it measure in (ie an oil pressure gauge reading to 80psi or 5.4bar is the same)
the problem is that people have been conditioned to use certain units and find it hard to adapt. PSI boost has much better bragging rights than KPA boost Razz heh heh
i do find it confusing when ppl say they have 25kpa at idle, as opposed to 75kpa absolute...
Nolan
Campbelltown, NSW
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 11:23 Go to previous messageGo to next message
Hey All,
i just wish i had a car that required a boost gauge Sad
that would be soo cool Laughing ive been trying to save up for a new car..somethign with power Laughing bu its just not happening...
stupid apprentice wages Razz
/rant
NOLAN
EVOSTi
cambo
      no
Re: Boost gauges. Please educate an ignorant old man. Wed, 09 March 2005 11:26 Go to previous message
bah, most gauges for automotive are in/Hg, so get a boost gauge with in/Hg and psi, does the job Very Happy
Previous Topic:2JZGE Soarer, extractors, exhaust
Next Topic:Respraying a ST-162 Celica SX...
Current Time: Sun Oct 18 00:38:23 UTC 2026
Total time taken to generate the page: 0.0055229663848877 seconds
