Toymods » Tech & Conversions » 1UZ sump issues
1UZ sump issues Tue, 05 November 2002 11:10 Go to next message
Finally started to do the 1UZ into HZ project, and as expected have got issues with the sump. We're using a Crown 1UZ with the mid sump, which is still too far forward to clear the crossmember. We hacked a (big!) hole in the floor/firewall, and it's still causing issues! Looks like we'll have to do something similiar to the one they did at Toyospares, and make a sump. Can anyone give any suggestions/ideas to help us out with this little issue? Also where abouts is the sump on a 2UZ (landcruiser)?
Re: 1UZ sump issues Tue, 05 November 2002 11:14 Go to previous messageGo to next message
What sump do you need? A front or a mid, I;m not sure from your description.
Re: 1UZ sump issues Tue, 05 November 2002 11:23 Go to previous messageGo to next message
Need a rear sump... Very Happy
Wasn't there a version of the 1UZFE with a rear-sump or am I dreaming? Razz
Re: 1UZ sump issues Tue, 05 November 2002 11:32 Go to previous messageGo to next message
Hmmmm, any chance your dreams might come true? Evil or Very Mad
Manny
Re: 1UZ sump issues Tue, 05 November 2002 12:13 Go to previous messageGo to next message
Soarer 1UZ sump is a rear isn't it?
Re: 1UZ sump issues Tue, 05 November 2002 13:10 Go to previous messageGo to next message
Pretty sure it ain't....
Re: 1UZ sump issues Tue, 05 November 2002 13:18 Go to previous messageGo to next message
Its front...
SupraPete
Re: 1UZ sump issues Tue, 05 November 2002 22:55 Go to previous messageGo to next message
I had to get a new sump for mine, I think its more mid than rear.
Will try another fit tomorrow (havn't tried it with new sump yet).
There are 3 different configs I *think* - lexus, soarer, crown.
I still don't bloody know which one I've got. My engine came out of a lexus apparently - front mount. So I got a rear (mid?) mount out of a soarer. as far as I know.
suprav8
melbourne
Re: 1UZ sump issues Thu, 07 November 2002 11:09 Go to previous messageGo to next message
Being a HZ you will need a rear sump......high energy in melbourne can modify any sump to your needs ....their prices are also very good!!!
www.highenergy.com.au
Loads of people(on here) are often asking about sumps for their 1uz conversions........Get the engine in,take some measurements and get someone who know`s what they are doing to modify it to your needs!!!.....it shouldn`t cost more than $200 for most conversions!....too easy!
Re: 1UZ sump issues Thu, 07 November 2002 13:43 Go to previous messageGo to next message
Ahhh... yeah forgot all about that mob Surprised I'll give 'em a call tomorrow, see what they suggest, otherwise just go on as we were and make a sump Confused
Re: 1UZ sump issues Fri, 08 November 2002 04:55 Go to previous messageGo to next message
Called High Energy this morning - 'Toyota make a V8? didn't know that... nah look we can give you one to put a Holden engine into a Hilux...'
Castlemaine Rod Shop are apparently working on a kit of sump, mounts, Xmember for this conversion though.
Re: 1UZ sump issues Fri, 08 November 2002 12:46 Go to previous messageGo to next message
I actually called them this morning about modifying a 2JZ sump......they couldn't quite come at the concept of a 2 part sump - cast aluminium upper and pressed steel tray.
Then you rang them with the "Toyota V8".....they must have thought it was the freaks day out!
Re: 1UZ sump issues Fri, 08 November 2002 12:55 Go to previous messageGo to next message
First time I tried to call them they didn't bother to pick up the phone. My later conversation was somewhat amusing though - 'Toyota? a V8? Are you sure you don't mean putting a V8 into a Toyota?' 'Quad cams, you sure about that? 4 litres, so its even smaller than a 253 is it? nah, don't get much call for stuff like that around here... We do kits for the Holden V6 though...'
I've got a good mind to call them again tomorrow!
biased99
Re: 1UZ sump issues Sat, 09 November 2002 07:16 Go to previous messageGo to next message
Fuck 'em...
There is only 1 V8 worth the effort...and we own one!!!
(Yes, it's a TOYOTA 1UZ-FE)
253...P-L-E-A-S-E!!!!
Re: 1UZ sump issues Sat, 09 November 2002 12:44 Go to previous messageGo to next message
There is another...the 3UZFE, exactly the same only 4.3l Smile Even crazier bore/stroke ratio too Smile
Re: 1UZ sump issues Sun, 10 November 2002 01:49 Go to previous messageGo to next message
ahhh, the 2sh!ttythree... and the 'good old' 308 - an engine so carefully constructed that it featured a devistatingly effective natural rev limiter - 5000+ = headless pistons! Nah I've still got some respect for the traditional V8's though, but nothing can beat the value for money aspect of the 1UZ - and the 3UZ is a fine thing too - dare I be a true plick and mention the nissan V8's while I'm at it? Evil or Very Mad
Re: 1UZ sump issues Sun, 10 November 2002 01:57 Go to previous messageGo to next message
The general concensus from what I've found is that the Infiniti (Nissan) V8's are really good, but not quite as thoroughly engineered as the 1UZFE and 3UZFE, even if they are slightly bigger capacities.
Re: 1UZ sump issues Sun, 10 November 2002 02:59 Go to previous messageGo to next message
Course the Toyota ones are better... they're.... Toyota! also much cheaper/more availble
DECPTN
Auckland NZ
Re: 1UZ sump issues Thu, 14 November 2002 10:10 Go to previous message
Hey re the sump issue I went through the same prob when i first started to build my hilux ute I ended up getting the front sump version, out of a aristo, but there is definatly 3 different version's of the sump front mid and rear if you want i will ring the wrecker and ask which came from which model as I can't remeber of the top of my head
Previous Topic:Auto box for TA22
Next Topic:Garret GT35/40
Current Time: Tue Oct 20 22:53:56 UTC 2026
Total time taken to generate the page: 0.0058159828186035 seconds
