Toymods » Tech & Conversions » t18 vs ta22 t series diff?
xolent
t18 vs ta22 t series diff? Wed, 09 March 2005 12:34 Go to next message
hi there, just a question for the tech heads out there,
what are the exact measurements between both the t18 diff and the ta22 diff, drum face to drum face?
are there any differences that i will be able to see, to spot a ta22 from a t18 diff?
thanx guys, i've tried searching but i couldn't find an answer.
ra23celica
Re: t18 vs ta22 t series diff? Wed, 09 March 2005 14:51 Go to previous messageGo to next message
Can't help you on the T18 but I have half a clue on the TA22. IIRC the rear track is 1285mm and the std steel wheel offset is 29mm, so that makes it something like 1342mm drum face to drum face, BTW some 30mm shorter than a RA23/28 axle.
Corrections to the above very welcome.
xolent
Re: t18 vs ta22 t series diff? Thu, 10 March 2005 10:22 Go to previous messageGo to next message
oh okay thens!
thanx for the help, really appreciate it!
any t18 guys out there?
xolent
Re: t18 vs ta22 t series diff? Fri, 11 March 2005 05:35 Go to previous messageGo to next message
anyone?
slydar
Re: t18 vs ta22 t series diff? Sat, 12 March 2005 02:09 Go to previous messageGo to next message
t18 very close to 1410 between the hub mounting surfaces.
xolent
Re: t18 vs ta22 t series diff? Sat, 12 March 2005 09:09 Go to previous messageGo to next message
1410?
woah that's different from what i've heard....
i'm about to buy one.. but he says from drum to drum, it's 1350
:S
IRA11Y
Club Member
Re: t18 vs ta22 t series diff? Sat, 12 March 2005 10:46 Go to previous messageGo to next message
T18 = 3.7, 3.9
TA22 = 3.9 4.1 4.3( optional extra)
the widths are different, TA22 is slightly narrower and has different mount points. T18 is the same width as a sprinter 1390'ish from memory
[Updated on: Sat, 12 March 2005 18:33]
ra23celica
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 00:30 Go to previous messageGo to next message
Sprinter width is 1410mm, if the T18 is the same then that is what you have got. Ain't no way that a T18 is as small as 1350mm.....that is very early (70's) Celica and Corolla territory.
Easy way to check is with the complete axle on the ground, minus the wheels, put a straight edge vertically across each drum face and measure between them with a tape.
xolent
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 01:21 Go to previous messageGo to next message
thanx ra23... i really appreciate the help!
do you mean those measurements by drum face to drumb face?
slydar
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 09:19 Go to previous messageGo to next message
1410 is the measurement we took from a disc brake ae86 rear end. rough-ishly. but id say we'd be within 15mm. i just assummed they run that sam track as an 86, might be wrong.
xolent
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 13:44 Go to previous messageGo to next message
oh alrights, so a t18 is the exact same width of a sprinter?
i'm asking because the diff i'm looking at might possibly go into a sprinter
ra23celica
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 14:47 Go to previous messageGo to next message
Yep - I was talking drum face to drum face.
Sam_Q
S.E suberbs, Vic
Re: t18 vs ta22 t series diff? Sun, 13 March 2005 22:35 Go to previous message
I can make some measurements if you need them, just say what you need.
Previous Topic:Coilover Setup??
Next Topic:6 speed into ma61?
Current Time: Sun Nov 1 05:45:43 UTC 2026
Total time taken to generate the page: 0.0061628818511963 seconds
