Toymods » Tech & Conversions » wobbly 18rgeu in an ra23
beterthenu
Dubbo NSW
wobbly 18rgeu in an ra23 Wed, 09 March 2005 13:46 Go to next message
i was wondering if these engines are meant to wobble so much?
mine has a lot of movement.
checked mounts, etc, they appear fine.
Is it supposed to have so much movement?
Re: wobbly 18rgeu in an ra23 Wed, 09 March 2005 13:53 Go to previous messageGo to next message
They're not a smooth running engine compared to modern equivalents; a bit of wobble is to be expected. It depends how much we're talking though.
stevenvandecauter
Belgium
Re: wobbly 18rgeu in an ra23 Wed, 09 March 2005 14:15 Go to previous messageGo to next message
Well, I guess it's better that the engine wobbles than the surroundings, meaning the chassis itself.
All engines wobble, and they should ! Smile
ra23celica
Re: wobbly 18rgeu in an ra23 Wed, 09 March 2005 14:43 Go to previous messageGo to next message
The bolts might be tight, but how old is the rubber of the mounts ? If its close to 30 years, I would be thinking about replacing them.
YelloRolla
On your mum!
Re: wobbly 18rgeu in an ra23 Thu, 10 March 2005 07:28 Go to previous messageGo to next message
stevenvandecauter wrote on Thu, 10 March 2005 01:15
I have balanced a coin on its edge on the cam cover of teh idling 7M GE - no visible "wobbling" there? (must be replaced soon with 1JZ)........
I vote that your engine mounts are prolly shot from having 18RG sized oil leaks over them.
beterthenu
Dubbo NSW
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 01:20 Go to previous messageGo to next message
hrmmm. it does move a lot say about 15cm side to side.
soaringmik
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 03:20 Go to previous messageGo to next message
beterthenu wrote on Fri, 11 March 2005 12:20
Shocked
river
Land of Oz
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 05:00 Go to previous messageGo to next message
15cm! Are you serious? That's 6inchs - more than your hand width! I'd be looking at your engine mounts if it was moving that much.
seeyuzz
river
beterthenu
Dubbo NSW
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 05:39 Go to previous messageGo to next message
yeah, its got a fair bit of movement. pulled the mounts out, they look fine - no cracks or anything.
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 06:43 Go to previous messageGo to next message
Are you sure the crossmember is bolted in dude?
15cm is a phenomenal amount.
Time to replace lots of stuff.
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 06:44 Go to previous messageGo to next message
Even 15mm is too much IMO
YelloRolla
On your mum!
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 07:49 Go to previous messageGo to next message
15cm is ridiculous and unbelievable.
My 3T doesn't even wobble 1.5mm. I barely have 18mm until the intake manifold wipes out the brake master cyl.
RA28midge
Adelaide and Queenstown T...
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 09:08 Go to previous messageGo to next message
How many cylinders are you running on?
They run on 3 cylinders fairly well, but will be wobbly. take out one spark plug at a time to see if the engine dies. If it does then it is dropping to 2 cylinders.
It took me a while to realise mine was only running on 3 when I first put it in.
beterthenu
Dubbo NSW
Re: wobbly 18rgeu in an ra23 Fri, 11 March 2005 14:44 Go to previous messageGo to next message
yeah, it wobbles a lot, which is why I'm worried.
YelloRolla - I'll see if i can get a quick vid of it. its not nice.
When it does move, its violent thrashing in the engine bay.
normo
Tamworth NSW
Re: wobbly 18rgeu in an ra23 Sun, 27 March 2005 12:20 Go to previous message
Pulling the plug leads off one at a time is a great idea. Your engine appears to be running on 2 or 3 cylinders. When you pull a lead off and it makes no difference note which cylinder it is (may be more than 1)
Check the plugs first, you can remove the plug and connect the lead and see if the plug is sparking.
If this is not the problem check your points in the dizzy they may be shot.
Let us know what the fix is
Previous Topic:dog box
Next Topic:3K Rally Motor Performance Rebuild to 1400cc
Current Time: Fri Nov 20 16:35:29 UTC 2026
Total time taken to generate the page: 0.022617101669312 seconds
