Toymods » Tech & Conversions » Apexi SAFC
b05c0
Apexi SAFC Wed, 09 March 2005 19:48 Go to next message
I am wondering if Apexi SAFC or AFC can fix up engine hunting problem.
Joshstix
Toymods Vice President
Re: Apexi SAFC Thu, 10 March 2005 03:35 Go to previous messageGo to next message
Why does the car hunt?
If it's a 4AGE then most likely it's air in the coolant or if it's a 4AGZE then it's pretty much by design.
The SAFC generally has a tendency to do the opposite of fixing problems in my experience.
Ribbo
Northern Beaches
Re: Apexi SAFC Thu, 10 March 2005 08:29 Go to previous messageGo to next message
Yes an SAFC won't help your problem, your problem will be else where.
An SAFC will only make things worse... mine has given me a slightly worse idle and its not even suppose to be doing anything...
IRA11Y
Club Member
Re: Apexi SAFC Thu, 10 March 2005 08:38 Go to previous messageGo to next message
hunting on a 4age can also be related to a TPS needing recalibration
Re: Apexi SAFC Thu, 10 March 2005 08:59 Go to previous messageGo to next message
Ribbo wrote on Thu, 10 March 2005 19:29
LOL Laughing that's a glowing testimonial if i ever heard one Wink
RA28midge
Adelaide and Queenstown T...
Re: Apexi SAFC Fri, 11 March 2005 03:13 Go to previous messageGo to next message
Are you serious?
Was it tuned on a dyno?
Ribbo
Northern Beaches
Re: Apexi SAFC Fri, 11 March 2005 08:35 Go to previous messageGo to next message
everything has been set to +-0, SAFC isn't even suppose to be doing anything but sitting there lol
It is now harder to start, I can't put all this all down to the SAFC though cos it does have its moods even before, but it definatly hasn't helped
cooter
perth
Re: Apexi SAFC Sat, 12 March 2005 08:26 Go to previous messageGo to next message
hey can someone enlighten me on what a safc is? and what does it do.
craig
Soarer
Wollongong
Re: Apexi SAFC Sat, 12 March 2005 23:12 Go to previous message
Adjusts fuelling over the rev range. Used as a cheap alternative to a fully programmable ECU if you can't justify the cost if you only need to play with fuel mixtures.
Previous Topic:celica's super and unleaded fuel when did they change
Next Topic:Compatibily between MA70 and GZ20 diff
Current Time: Fri Oct 30 06:21:17 UTC 2026
Total time taken to generate the page: 0.20194721221924 seconds
