Toymods » Tech & Conversions » My 1G Needs A Rebuild...
1G-GTE KE70
icon5.gif  My 1G Needs A Rebuild... Thu, 10 March 2005 09:53 Go to next message
It blows smoke. white smoke. a lot on startup then it reduces a bit. but it still always smokes no matter how long you drive it for.
does anyone know where I can get a rebuild kit from?
Pistons and rings
Bearings
Gaskets
I might source them through 680OST seeings as the mods rudely closed both threads about the group buy which was to help source very hard to find parts for our engines..
but yeah any help would be good.
I've got new valve stem seals waiting at home so I don't need them but that's not the problem..
Thanks guys!
jackel
Re: My 1G Needs A Rebuild... Thu, 10 March 2005 10:18 Go to previous messageGo to next message
isn't white smoke got to do with the turbo?
does it blow shitloads on boost?
blue smoke is oil so doubt you'll need piston rings
HyDrA
Adelaide, SA
Re: My 1G Needs A Rebuild... Thu, 10 March 2005 10:50 Go to previous messageGo to next message
It could just be the valve stem seals... if it happens after vacuum (startup, idle, engine braking).
But you might not be able to just replace the seals, you might also have to replace the valve guides, if they are worn the seals will be destroyed in no time.
Re: My 1G Needs A Rebuild... Thu, 10 March 2005 12:31 Go to previous messageGo to next message
If the smoke is actually white, that's steam. Almost certainly BHG.
If the smoke is blue-ish, that's oil. Valve stem seals, turbo oil seals, or piston rings (increasing order of liklihood).
MR 1JZ
Re: My 1G Needs A Rebuild... Thu, 10 March 2005 13:27 Go to previous messageGo to next message
yes i concur with norbie, when my 1G had a leaky HG it would blow white smoke on startup, probably from water seeping into the combustion chamber and when the engine got hot and i pushed it white smoke would pour from the exhaust.
Most probably not the bottom end
YelloRolla
On your mum!
Re: My 1G Needs A Rebuild... Thu, 10 March 2005 13:44 Go to previous messageGo to next message
1G-GTE KE70 wrote on Thu, 10 March 2005 20:53
What a great idea. While you're at it why not ask why he did not co-operate with the mods and try to get an approval for his group buy?
Fattony
Re: My 1G Needs A Rebuild... Fri, 11 March 2005 05:25 Go to previous messageGo to next message
For $400 odd dollars you can easily find yourself another 1ggte and just plop that in rather than fart about with wat could be the problem
1G-GTE KE70
Re: My 1G Needs A Rebuild... Fri, 11 March 2005 09:07 Go to previous message
I had that exact thought today. I will probably do that.
it's not the turbo because I just got it back from a rebuild. it did it before the rebuild and it still does it now. when it hits boost it runs rich as (lpg) which obviously has to do with tuning. it stinks hardcore like lpg too.
I am not sure about the smoke colour when it hits boost because the dark blacky/blue smoke takes over haha.
white smoke is oil. my brother (mechanic) reckons it might be the piston rings as well.
ahh stuff it i'll just get a new 1G instead of pulling this one apart.
wo0t
can anyone get me a cheap good one in Brisbane?
I only need the engine, no turbo's, injectors etc.
Thanks for your help but
Previous Topic:1UZ into RA28?
Next Topic:Replacement Hand brake Cable???? Who makes themn???
Current Time: Sat Oct 17 04:07:56 UTC 2026
Total time taken to generate the page: 0.024618148803711 seconds
