Toymods » Tech & Conversions » Auto - > Manual Conversion
CamZH
Toodyay, WA
Auto - > Manual Conversion Tue, 05 November 2002 19:08 Go to next message
Hey guys,
Can i use a RA65 and get all the bits from it to convert a auto RA28 to a manual??
is there some parts that need to come from the 23/28 series??
CamZH
ra23celicachick
Mornington Peninsula
Re: Auto - > Manual Conversion Wed, 06 November 2002 01:09 Go to previous messageGo to next message
Depends on the engine. If both are R series engines you should be able to use them. Not sure what bit's you'll need though. Probably bell housing, diff, slave and master cylinders etc. Don't know too much about doing a conversion but if the engines are the same can't see too much of a problem
Re: Auto - > Manual Conversion Wed, 06 November 2002 03:58 Go to previous messageGo to next message
The RA6x has a W55 or W57 transmission, while the RA28 has a W50. You can make it fit but it won't be a direct swap. Stuff like the clutch pedal and hydraulics will be the same deal - similar, but not exactly the same. You're much better off getting all the required parts from an RA23/28/40 donor car.
RA28
Re: Auto - > Manual Conversion Wed, 06 November 2002 05:03 Go to previous message
I used a RA60 to convert mine. The gearbox will fit with a slightly modifyed cross member, the pedal box is a pain in the ass though. Much easier to get the pedals and pedal box from a wrecker. Also the master cylinder, your RA28 will have a hole but it'll be different, the bolts on the RA60 are on an angle whereas the RA28 is straight up and down. one arm goes under the brake booster so it's not all that easy (I only put one bolt in mine and it seems to hold OK).
Tim.
Previous Topic:Corolla AIR CON (74 - 79)
Next Topic:MAP Sensors and Airflow meters.
Current Time: Mon Oct 12 14:32:11 UTC 2026
Total time taken to generate the page: 0.082066059112549 seconds
