Toymods » Tech & Conversions » AE82 to AE92 Rear Disc Brake conversion
EvilJack
Sutho/Hills NSW
AE82 to AE92 Rear Disc Brake conversion Tue, 05 November 2002 21:15 Go to next message
just wondering if anyone knows if the AE82 rear twincam brakes bolt onto the ae92. are they a straight up swap or is there any minor or major modifications? thanx
AE82TwinCam
Canberra, ACT
Re: AE82 to AE92 Rear Disc Brake conversion Tue, 05 November 2002 23:21 Go to previous messageGo to next message
umm I don't think so...
I have a set of ae92 rear discs and calipers for my ae82 sitting in the garage and thats because the bolt points are about 5mm to long to fit on to my ae82 mounting bracket.. so my guess is it won't work the other way around either.
I will find out next week how much it will be for me to get a set of custom brackets made up by my local machining shop
-Andrew
Browndog
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 00:55 Go to previous messageGo to next message
I'm keen to hear if you got that to work or not AE82TwinCam, what sort of brakes are on there now (i.e. before you put the AE92 disks on)?
[Updated on: Wed, 06 November 2002 00:57]
EvilJack
Sutho/Hills NSW
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 04:08 Go to previous messageGo to next message
I just have the stock drums on the back.
i can get a ae92 set its just i was able to get a cheap set of ae82.
im probably safer with justing grabing a ae92 lot.
Bugman
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 04:10 Go to previous messageGo to next message
you guys should meet up in golburne and swap parts.
EvilJack
Sutho/Hills NSW
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 05:33 Go to previous messageGo to next message
whats the colour of your car bugman?
Rolla Boy
Club Member
Sydney, NSW
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 16:27 Go to previous messageGo to next message
Andrew,
I watched dudes at BD4's do a disc conversion on a CS AE92 and it was a bolt on job... Looked quite easy actually...
haggis
Re: AE82 to AE92 Rear Disc Brake conversion Wed, 06 November 2002 22:51 Go to previous messageGo to next message
If you are swaping AE92 drums out, and AE92 disks in, it is just a matter of bolting things in place. You may need to get new brake hoses tho. You will need not just the disk and caliper, but the hub carrier as well! The reason for this is the caliper bolts direct to the hub carrier unlike the AE82 which has a seperate backing plate that is changed for drum or disk.
Dont forget to get the hand brake cable for the disk setup!!!!
If you have all the parts ahead of time, you should be able to do the swap in an afternoon.
Craig.
Scorpion
Menai area of Sydney
Re: AE82 to AE92 Rear Disc Brake conversion Mon, 10 November 2003 07:01 Go to previous message
Can use AE92 disc brake flexible hoses. Connect from caliper straight to body and don't need to use the bracket on the strut.
Previous Topic:ta22 diff options and brakes question.
Next Topic:best parts for TA22 street racer
Current Time: Sat Oct 24 01:03:00 UTC 2026
Total time taken to generate the page: 0.0049149990081787 seconds
