Toymods » Tech & Conversions » How to tell if rings are worn
hokey
Kilsyth, Melbourne
How to tell if rings are worn Fri, 11 March 2005 10:03 Go to next message
Hey,
i hav a 3t stripped down and am making a 3tg. when the 3t was running it ran fine not blowing smoke or anything. i am just wonderin how i tell if the rings are worn at all cause i don't want to build it and then have to strip it down again.
thanx for the help,
Cheers, Calvin
Re: How to tell if rings are worn Fri, 11 March 2005 10:37 Go to previous messageGo to next message
Check bore for wear/taper. If within limits hone. Rings cost fuckall (relative to tearing down a motor after you have assembled it and run it to discover they are stuffed) so replace them.
EVOSTi
cambo
      no
Re: How to tell if rings are worn Fri, 11 March 2005 11:29 Go to previous messageGo to next message
yeah definately if you have the motor apart, do them. rings will generally cost around the $50 mark for a set.
towe_001
Somewhere on a dirt bowl ...
Re: How to tell if rings are worn Fri, 11 March 2005 12:29 Go to previous messageGo to next message
Yeah same boat. Check the bore for wear. But arn't the twin cam pistons different to the OHV pistons ? IMO i'd go straight for new rings since the motor's been striped
hokey
Kilsyth, Melbourne
Re: How to tell if rings are worn Fri, 11 March 2005 22:18 Go to previous messageGo to next message
towe_001 wrote on Fri, 11 March 2005 23:29
if u are talkin about 2tg and 3t pistons then yes. to put on the twincam head all you need to do is regrind the valve reliefs on the pistons.
-Calvin
81LOWLUX
BRAY PARK BRISBANE
March 2005
Re: How to tell if rings are worn Sat, 12 March 2005 02:52 Go to previous messageGo to next message
JUST REPLACE THEM AND YOU WONT HAVE TO WORRIE ABOUT IT FROM THERE. MAKE SURE YOU HONE THE BOARS THOUGH.
hokey
Kilsyth, Melbourne
Re: How to tell if rings are worn Sat, 12 March 2005 22:43 Go to previous messageGo to next message
when i get the block honed does anyone know if they will want a bare block or can i leave the crankshaft on and a couple of other things aswell?
Cheers, Calvin
EVOSTi
cambo
      no
Re: How to tell if rings are worn Sun, 13 March 2005 07:41 Go to previous message
yeah you can leave the crank in, its easier to do if you dont though. you can very easily hone it yourself tho if you get a honing tool and you have a drill. there is a very specific way to do it tho for those who think you cn just shove it in and go for it.
Previous Topic:cold air intake
Next Topic:which engine..?
Current Time: Sun Nov 22 09:39:46 UTC 2026
Total time taken to generate the page: 0.0059528350830078 seconds
