Toymods » Tech & Conversions » torque converter lockup
Chris Davey
sunny coast, qld
torque converter lockup Sat, 12 March 2005 00:26 Go to next message
Hi guys,
I have done a search here and other places and I am trying to find out some info. about torque converter lockups. Is this what the OD button does on standard autos? Or is it an automatic thing that is done via the ecu when it reaches certain conditions?
I have read on supraforums about people locking up the converter half way down the strip to increase MPH as it is then at 1:1 ie. no slippage. Although they said that this is not recommended as it wears things out quickly. They said it is fine to do while on the highway etc. but not at WOT.
The reason for this question is the mechanic I took my car to said that I would have to drive around everywhere around town in 1st or 2nd gear only if you have a high stall torque converter. I don't know how high a stall I will need yet but I would think around 3500rpm as I am running a ta45s on a 1jz-gte. The other thing he said was that I would not be able to use the OD. I was a little confused by this also.
I have read up on howstuffworks also to get a basic knowledge base but can't quite work out what he was referring to.
BTW I am running an a340e and it will be modded to handle the power most likely by MV autos.
thanks in advance
Re: torque converter lockup Sat, 12 March 2005 00:43 Go to previous messageGo to next message
funny you should ask.
the current copy of "Performance Buildups" has a torque converter special in it. 7 pages and heaps of pics. well worth $7 if you can find a copy.
http://www.universalmagazines.com.au/home/performa nce_buildups
Chris Davey
sunny coast, qld
Re: torque converter lockup Sat, 12 March 2005 08:23 Go to previous messageGo to next message
thanks mate, I will go and grab a copy.
Re: torque converter lockup Sat, 12 March 2005 09:38 Go to previous message
The lockup function of the torque converter is NOT designed to handle heavy loads; that's why it's only engaged under light cruise conditions.
Previous Topic:GZ help a very tough question
Next Topic:hi to everyone/bunderra question
Current Time: Fri Nov 20 08:25:34 UTC 2026
Total time taken to generate the page: 0.0057599544525146 seconds
