Toymods » Tech & Conversions » CHEAP 18R MODS
81LOWLUX
BRAY PARK BRISBANE
March 2005
icon5.gif  CHEAP 18R MODS Sat, 12 March 2005 01:42 Go to next message
DOES ANY ONE KNOW HOW TO GET CHEAP PERFORMANCE OUT OF THEM ILL DO ALL TH WORK MYSELF. I GOT 2X 18R'S AND 1X 16R.
WAS THINKING 18R BLOCK CRANK AND RODS, 16R HEAD, 22R PISTONS?
CAN YOU HELP?
[Updated on: Sat, 12 March 2005 02:37]
Major Clod
Re: CHEAP 18R MODS Sat, 12 March 2005 07:13 Go to previous messageGo to next message
Easiest would be to just dump the 18R and put in an 18RG. Twin cam crossflow head, twin carbs, should put out around 90-100kw at the flywheel. As a bonus there are a few in the for sale section at the moment... Its probably going to be the cheapest way to increase performance.
The biggest hassel is rigging up a cable to the throttle, but get the pedal and cable out of an RA65 and you should be set.
You can also get an EFI version of the engine but this will require some work on your fuel system as well.
brett_celicacoupe
townsville NQLD
Re: CHEAP 18R MODS Sat, 12 March 2005 10:38 Go to previous messageGo to next message
Major Clod wrote on Sat, 12 March 2005 18:13
u dont need to convert to cable if u dont want to. they origionally are made to utilize the links setup.....you only need to shorten one of the links and remount a pivot to go from 18rc --> 18rg (except GEU)
although i would suggest cable.
i used a MX62 cressida cable and pedal...easy to put in
brett
jeffro RA28
Tamworth
Re: CHEAP 18R MODS Sun, 13 March 2005 04:42 Go to previous message
Mild Cams plus extractors always.
If uv got the resources and know how to port n polish do that. Bare in mind that the overall finish of ports only counts for 4% of the air flow. The major browny points for gaining air flow is the material u take out, not the surface finish of ur ports.
Previous Topic:aircon oil cooler
Next Topic:Wiring Help
Current Time: Tue Oct 27 03:51:15 UTC 2026
Total time taken to generate the page: 0.0058081150054932 seconds
