Toymods » Tech & Conversions » 2t dieseling on.
jeffro RA28
Tamworth
2t dieseling on. Sun, 13 March 2005 06:28 Go to next message
Just recently getting my 2t in my ta23 ready for blueslipping.
I Tuned it up etc, set the idle, cleaned the points, set the points, adjusted the timing to 10 deg advanced (recomended by manual) Replaced the carby with a fresh one that had been restored, set spark plug gap.
Just after getting the car running sweet, i noticed it decided to run for about another 5 seconds after turning it off. It seems to die then re-gain its revs then die for good. Then a heap of smoke comes out of the carby. The engine hesitated to start after doing this, but when i got it to start it sounded like there was a dull noise towards the front of the engine, sort of like a knocking, but stayed constant, there was also a bit of noise that stayed constant while the knocking was occuring. I then turned the car of agen and agen trying to get it to do it again but it wouldnt, it only happens every so often.
The only thing that i think it could be is carbon build up on the pistons and in the combustion chamber. Or a faulty fuel pump.
The engine wont idle very smooth either, it idles sorta ok but not great. When driving it in first gear with no throttle it feels like i have got lumpy cams but it is an irregular jolting, if u know wat i mean.
Before fine tuning it, it would do a similar thing when the car was running, but would finish up stopping the engine without turning the key off.
I also noticed that when on ramps facing the car uphill, the engine idles much higher, but then when facing downhill the car will idle so low it causes it to stop. I jumped in my sisters Mazda 323, to see if it would do the same thing(slightly) and it didnt, probly because it is fuel injected. I think perhaps a leaking float, that gets fuel in it could be causing this.
I have lack of knowledge with engines, i am only 15 so i dont know whether these old cars change their idle when heading up hill or not.
It is only going to be my dialy driver whilst i am getting my RA28 project car sprayed and rebuilding the 18r myself. So i am not going to bother doing anything about it if it is somthing internal, such as sticking valves or heavily carbonized combustion chamber. But if it is somthing small i would prefer to fix the problem.
I have another ta23 with all the spares to swap parts over so that isnt a problem. I was thinking of swapping the fuel pump to see if that fixed the problem but i thought i would consult toymods first.
If anyone could enlighten me as to what is wrong with my car i would be very much apprecative.
Regards, Jeff
Moonbreaker
Re: 2t dieseling on. Sun, 13 March 2005 09:01 Go to previous messageGo to next message
try rebuilding your carb that'll probably solve the problem
jeffro RA28
Tamworth
Re: 2t dieseling on. Sun, 13 March 2005 09:28 Go to previous messageGo to next message
It has got a reconditioned carb as said in my first post. I dont know whether it has been rebuilt but it has been checked over and all gaskets etc have been replaced. I doubt there is a need to rebuild it. I can always swap the newer carb with the previous carb and see wat happens tho.
jesseT18
Castle Hill, Sydney
Re: 2t dieseling on. Sun, 13 March 2005 09:49 Go to previous messageGo to next message
did you change the cam timing at all?
jeffro RA28
Tamworth
Re: 2t dieseling on. Sun, 13 March 2005 09:50 Go to previous messageGo to next message
Nope, maybe i should check it tho.
jesseT18
Castle Hill, Sydney
Re: 2t dieseling on. Sun, 13 March 2005 09:53 Go to previous messageGo to next message
might be better to leave it alone, if its only started doing it now and you havent changed the timing.
its just that cam timing being out can cause ...
and also make it run on, but if it aint broke, dont fix it!
sounds like carb!
Moonbreaker
Re: 2t dieseling on. Sun, 13 March 2005 13:23 Go to previous messageGo to next message
best thing to check in the carb wuld eb the needle vavle that is controlled by the float it could probably be sticking. sometimes the reconditioning only changes gaskets and does rebuild of major parts but dont check smaller stuff like these
jeffro RA28
Tamworth
Re: 2t dieseling on. Mon, 14 March 2005 07:31 Go to previous messageGo to next message
Can anyone else suggest anything that could be wrong with my car?
+ bump
YelloRolla
On your mum!
Re: 2t dieseling on. Mon, 14 March 2005 07:53 Go to previous messageGo to next message
smoke coming from the carb is a normal condition when you kill the engine (exhaust fumes left within the combustion chamber escape during the overlap period - and the engine will quite often kick backwards about 90deg or so).
When setting the ign timing did you use a timing light with the ign advance dial on the back? If so you may be running 20deg adv or something like that.
Some Tojo engines have 2 x timing marks - the first will be 10deg BTDC and the other will be TDC - make sure that this is all clear and that you have not made some mistake (I have seen when the wrong timing cover is being used and this can fuck things right up). Picture a 2TG with a 3TGTE front pulley on it = wrong.
Test it by winding some advance out of it and try starting the engine again and shutting it down.
If the car has been sitting for a long time the fuel may be shit and may cause some engine run on.
jeffro RA28
Tamworth
Re: 2t dieseling on. Mon, 14 March 2005 07:57 Go to previous message
Cheers, I will try all that.
I know about the stale petrol thing and did replace it with some fresh stuff.
Previous Topic:Tail lights and dash light not working
Next Topic:What to do
Current Time: Thu Nov 19 00:45:30 UTC 2026
Total time taken to generate the page: 0.0075688362121582 seconds
