Toymods » Tech & Conversions » 3SGTE problems
WantaTurbo
3SGTE problems Sun, 13 March 2005 23:23 Go to next message
Hey i dunno if im just being picky about my car but lately the engine has felt alot rougher especially when its cold. Im just wondering what kind of things could be the problem and where to go to get it fixed or checked up? Im thinkin the timing could be out ? but im not really sure cause still pretty a newbie with cars. Any help would be greatly appreciated !! Thanx,
Bill
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 3SGTE problems Sun, 13 March 2005 23:24 Go to previous messageGo to next message
headgasket?
WantaTurbo
Re: 3SGTE problems Sun, 13 March 2005 23:44 Go to previous messageGo to next message
-==L=a=N=c=E==- wrote on Mon, 14 March 2005 10:24
headgasket?
no idea? what kinda effects does headgasket have? and how hard/expensive r they to fix ?
-==L=a=N=c=E==-
Re: 3SGTE problems Sun, 13 March 2005 23:48 Go to previous messageGo to next message
if its driving a bit rough, possibly low compression in any ofhe cylinders.
rings could have seen better days as well.
WantaTurbo
Re: 3SGTE problems Sun, 13 March 2005 23:55 Go to previous messageGo to next message
-==L=a=N=c=E==- wrote on Mon, 14 March 2005 10:48
Cool thanx might get compression test done on the cylinders.... anything else it could be ? what kinda of a place would i go to get my engine checked out ? normal mechanic do it ? Thanx
-==L=a=N=c=E==-
Re: 3SGTE problems Mon, 14 March 2005 00:00 Go to previous messageGo to next message
it could also be some tired spark plugs.
Basically what im saying, it could be anything.
Any mechanic can have a look at it and tell you wahts wrong with it straight away.
WantaTurbo
Re: 3SGTE problems Mon, 14 March 2005 00:08 Go to previous messageGo to next message
Sweet thanx mate.
ra23celica
Re: 3SGTE problems Mon, 14 March 2005 11:42 Go to previous messageGo to next message
Check all the vaccum hoses for leaks/sucking/pumping air.....don't assume its the worst case until you have eliminated everything else !
WantaTurbo
Re: 3SGTE problems Mon, 14 March 2005 21:49 Go to previous messageGo to next message
ra23celica wrote on Mon, 14 March 2005 22:42
Definitely i dont wanna believe its somethin real bad till i have made sure of everythin else.
MR. 2
Parramatta
Re: 3SGTE problems Tue, 15 March 2005 05:08 Go to previous messageGo to next message
if i were you i would do the general mantiance on the car
change the spark plugs
change the leads
change the coil
as said make sure none of the vacum hoses has fallen off.
if this is a gt4 while the top mount cooler is off, clean it out you will be amazed at all the oil that will come out and you might seen and extra pound of boost.
[Updated on: Tue, 15 March 2005 05:09]
Joshstix
Toymods Vice President
Re: 3SGTE problems Tue, 15 March 2005 06:46 Go to previous messageGo to next message
Definately do a compression test. It's quite common for these engines to crack the ring lands on pistons 2 and 3.
WantaTurbo
Re: 3SGTE problems Tue, 15 March 2005 22:14 Go to previous message
Yep will do thanx for input guys. Gonna do general maintenance this weekend eg, check plugs, leads, points, dizzy and check any vacuum hoses. The engine only has 60k on it so im just hopin its somethin little. If i cant resolve it on the weekend it will go into a mechanic to get the engine checked up and compression tested as well as tuning id say.
Previous Topic:coilovers for AE86 sprinter
Next Topic:Hiperboost
Current Time: Sat Nov 21 08:21:47 UTC 2026
Total time taken to generate the page: 0.004478931427002 seconds
