Toymods » Tech & Conversions » 1UZ error codes and diagnosis
Skip
1UZ error codes and diagnosis Mon, 14 March 2005 00:06 Go to next message
Guys,
A friend has a LS400 which has had the check engine light on now for a few months.
Will the following procedure work with the 1UZ?
http://www.club4ag.com/faq%20and%20tech_pages/ECU% 20Diagnostic%20Codes.htm
[Updated on: Mon, 14 March 2005 00:07]
Toobs
Re: 1UZ error codes and diagnosis Mon, 14 March 2005 00:43 Go to previous messageGo to next message
It would work but the code list isn't the same.
i.e. bridge TE1 & E1 terminals on the check connector and then flick the key to ignition and the codes flash out via the check engine light on your dash.
Codes can be had here: http://www.lextreme.com/Lex%20DxCode.pdf
Lextreme has heaps of info on the 1UZ... definately a worthwhile site / forum to become a member of if you've got a 1UZ.
Skip
Re: 1UZ error codes and diagnosis Mon, 14 March 2005 02:15 Go to previous messageGo to next message
Cheers Toobs
Just one more question when you pop the cap of the connector cluster are the terminals TE1 and E1 clearly labelled? And when they say "short" the terminals they mean bridge one to the other yeah?
Re: 1UZ error codes and diagnosis Mon, 14 March 2005 03:49 Go to previous messageGo to next message
Skip wrote on Mon, 14 March 2005 10:15
Cheers Toobs
Yes, and Yes
Its on the front corner of the plenum.
Toobs
Re: 1UZ error codes and diagnosis Mon, 14 March 2005 06:15 Go to previous messageGo to next message
There should be a label under the cap of the diag connector showing whats what.
I always use a paperclip to short the connections... i.e. stuff one end of the now straightened paperclip in TE1 and the other end in E1.
Skip
Re: 1UZ error codes and diagnosis Mon, 14 March 2005 23:44 Go to previous messageGo to next message
Thanks for the excellent help so far guys.
I did the diagnostic last night and I pulled only 1 error code from it number 41 which is TPS. The car drives fine with no problems so I can only assume its a little out of calibration or something. Where to now?
Re: 1UZ error codes and diagnosis Tue, 15 March 2005 00:50 Go to previous messageGo to next message
Just check the TPS
http://www.oz-enet.com.au/~peewee/1uz_ecu.gif
Look at the wiring.
Make sure the TPS is in IDL when the TB is full closed, and that the resistance varies in a similar manner to other Toyota's, when you move the throttle plate.
The throttle plate could very well just be gummed a few mm open by crap.
Clean it with some carby cleaner, reset the ecu, take it for another drive, pull the codes again.
Skip
Re: 1UZ error codes and diagnosis Tue, 15 March 2005 01:35 Go to previous messageGo to next message
Cheers Andrew.
One more dumb question how do you reset the ECU?
Re: 1UZ error codes and diagnosis Tue, 15 March 2005 01:46 Go to previous message
Pull the EFI fuse for a few mins.
Cuts the memory for the ecu
Previous Topic:MA70 front on Soarer?
Next Topic:vvt-i Corolla minor mod query
Current Time: Thu Nov 19 13:27:56 UTC 2026
Total time taken to generate the page: 0.012457132339478 seconds
