Toymods » Tech & Conversions » 1jz ignition?
Rossco
1jz ignition? Mon, 14 March 2005 10:43 Go to next message
started up my soarer yesterday for first time and it ran fine bar an oil leak i knew about. so i switch it off after about 5-8 secx of running
started it up for another 5 sec fine fine again
today i fixed the oil leak ( broken bolt in remote oil filter relocation kit) tired t start it and it wouldnt start
with the engine off, and the key in the " on" position but not yet turned to start im getting spark in #1 plug
how is that even possible?
can i narrow it down to CAS, ECU or some wiring inbetween the 2?
any help or idea would be great
i bought the car from japan under the assumption the engine didnt run , auction sheet says "engine does not inhale) , but it strated 2nd crank after being on the docks for over 8 months.... is confusing
ROss
[Updated on: Mon, 14 March 2005 10:43]
Re: 1jz ignition? Mon, 14 March 2005 11:01 Go to previous messageGo to next message
Rossco wrote on Mon, 14 March 2005 18:43
Errr, am I reading this correctly?
Rossco
Re: 1jz ignition? Mon, 14 March 2005 11:17 Go to previous messageGo to next message
haha u sure are
engine is not in motion
and im getting spark in #1
prolly sparks 3 times a sec
what on earth could cause it
ROss
Re: 1jz ignition? Mon, 14 March 2005 11:22 Go to previous messageGo to next message
My god that is odd.
Yeah, start checking around for a plug that has come undone.
Do any other of the plugs have spark?
It is possible that the ignition module is stuffed.
I wouldn't think its a sensor problem though.
Rossco
Re: 1jz ignition? Mon, 14 March 2005 11:25 Go to previous messageGo to next message
my starter motor is pretty cactus so gettn it to crank over is a mission, so testing other plugs for spark is pretty hard
ive tried disconnectin #1 and cranking it over
to no avail, cranks over and wont fire, guessing they are not gettin any spark, or its too weak
know anyone in perth i could score a module off or even a 1jz ecu to try?
ROss
Rossco
Re: 1jz ignition? Mon, 14 March 2005 11:26 Go to previous messageGo to next message
i cant see it being something castistrophic since it was runnign yesterday fine
and i aint touched fuck all
Rossco
Re: 1jz ignition? Mon, 14 March 2005 11:27 Go to previous messageGo to next message
to trouble shoot
what should i be looking at?
what gives the coil its signel/power
start of it is ecu then some wire to ignitor?
whats in between
been waiting 8 month for this to come haha i just wanan go for one lap around the block
gotta ge the fucker started
ROss
[Updated on: Mon, 14 March 2005 11:28]
Re: 1jz ignition? Mon, 14 March 2005 11:33 Go to previous messageGo to next message
I meant do any of the other plugs have this mysterious spark?
Or is it just number 1?
Does the fuel pump turn on?
I'm not sure how the 1jz coil setup is, but normally the coils have power from the ignition main relay, which inturn gets its power from the fuse box.
Download this file
http://toymods.org.au/Repository/TechDocs/1JZ-GTE% 20Electricals.zip
3meg.
It may help.
Coil signal comes from the ignitor, which inturn gets the signal from the cam angle sensor, which is where you would normally find the dizzy.
Rossco
Re: 1jz ignition? Mon, 14 March 2005 11:43 Go to previous messageGo to next message
i dont even knwo where the CAM sensor is on a 1jz surely aint clearly visible
im at a loss to why the coil is even gettn signal to fire
ROss
Re: 1jz ignition? Mon, 14 March 2005 11:51 Go to previous messageGo to next message
Rossco wrote on Mon, 14 March 2005 19:43
I'd say its a faulty ignitor (at a random guess)
CAS should be on drivers side, front of the motor, on the side of the head.
Rossco
Re: 1jz ignition? Mon, 14 March 2005 12:11 Go to previous messageGo to next message
hmm perplexing
cheers for your help andrew
if i aint sorted it by week and u aint busy, care to swing by and have a gander?
hook ya up with a few beers for your trouble
rOss
Re: 1jz ignition? Mon, 14 March 2005 12:20 Go to previous messageGo to next message
Would love to help, but it goes past my expertise.
All I would do is check plugs are in, and swap the ignitor and the ecu.
If that doesn't fix it, then its off to the professionals.
Its not runnig S-AFC or anything like that is it?
Could that be doing anything on its own?
82MKII
Re: 1jz ignition? Mon, 14 March 2005 14:21 Go to previous messageGo to next message
Whever I've been suspicious of ignition problems I've always done the following:
1. Pull out all the plugs, put them back in the coilpacks & lay them on top of the cam covers (so that the coilpacks & plugs have a good earth connection).
2. Disconnect the starter motor power (so it can't be accidentally run)
3. Switch the ignition to ON
4. Turn the motor over slowly by hand (socket on main bolt)
After about 2 revolutions, the spark plugs will start to fire as you rotate the engine. The order is (as you'd expect) 1 5 3 6 2 4.
If you still get this strange multiple spark problem then something is wrong with either the ECU or Ignitor. If some of the sparks appear 'weak' compared to the others, then it is probably just time for new plugs (1Js have a healthy appetite for new plugs).
Regards
Peter
Skip
Re: 1jz ignition? Mon, 14 March 2005 23:39 Go to previous messageGo to next message
If you pull all your sparks out the engine will turn over alot easier, save your battery.
What is the wiring like in the car, good job or grubby?
If you want to find the crank angle sensor plug its down behind the alternator. The entire length of crank angle wire should be well shielded as they are supsebtable to electric interference. It sorta sounds like the ign system has been wired up to a source of constant +12V power (dodge). Then there is another wire for another system in the car which also has constant +12V power running near a section of exposed CAS wire hence cause the interference and giving the CAS a signal which is inturn firing the spark.
I assume the entire loom is intact so you may find its a section of CAS wire that may have been melted, so start checking. If you want to try another igniter I have one sitting in my hot little hand right now. Also check where the power source wire for the ignitor is going to, the wire is black with an orange stripe coming out of the small black plug.
Rossco
Re: 1jz ignition? Sat, 19 March 2005 09:12 Go to previous messageGo to next message
had a little success with diagnosing the problem
kinda gave up for alittle bit and decided to give the engine bay a
little wash down
tried strating it aftetr that and viola!!
engine fired up
ran it for about 10 mins. engine sounded good, didnt over heat a
little black smoek was comming out the exhuast not sure if thats rings
or just coz the engine hasnt been run for over 8 months
i stalled it trying to reverse ( triple plate)
and from then on its being gay again, spark on #1
had it running just before and wouldnt run unless foot was on accel
was missing badly as in wasnt running on all cyls
sounded like its just a wire r somthign somehwere that i knocked into
the right place when i washed the car?
where exactly is the crank/cam angle sensor/s i cant fine it/them
ROss
Skip
Re: 1jz ignition? Sun, 20 March 2005 07:24 Go to previous message
There is 2 cam angle sensors on the passenger side of the head. One is at the very rear of the engine the other is half way down.
I dont know where the Crank angle sensor is in the block exactly all i can tell you is the plug for it is down next to the alternator.
Previous Topic:1GGTE - 1GGZE
Next Topic:soarer gearbox convertion...
Current Time: Wed Oct 14 09:51:40 UTC 2026
Total time taken to generate the page: 0.079166889190674 seconds
