Toymods » Tech & Conversions » Actual Temprature Reading (MA61 Dash)?
ZZT231
melbourne.vic.au
Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 00:12 Go to next message
Hey All,
What is the actual temprature reading on an MA61 per bar on the digital readout?
Cheers.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 01:05 Go to previous messageGo to next message
id be guessing either 20 or 30 deg per bar
bbaacchhyy
Re: Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 01:14 Go to previous messageGo to next message
ViPeR_NiPPleX wrote on Tue, 15 March 2005 11:35
Bad guess.
Easiest way if it is not listed in the TRSM, is to get a multimeter and temp probe and watch the bars light up from cold and note the temp.
Typically, gauges start at about 50 deg and the top of scale is about 150, and centre should be about 90 to 100 degrees. It may not be linear either.
Celia-Sue
Re: Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 02:10 Go to previous messageGo to next message
Sorry - I havn't mapped it out yet. But, comparing the Haltech display to digital dash indicates that (a) it's not linear and (b) it shifts to the mid-way bar at around 88 degrees.
Re: Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 12:08 Go to previous messageGo to next message
You are correct, it's definitely not a linear scale. From memory most of the movement is a few degrees above and below the "middle" temperature.
Re: Actual Temprature Reading (MA61 Dash)? Tue, 15 March 2005 12:31 Go to previous message
My MX73 guage (which would use the same sender as MA61), doesn't move from 80deg C to 95deg C.
It will move up once the water temp is about 98, and when it hits 100 the guage is over 3/4
I would hazard a guess that the MA61 would be identical to this
Previous Topic:Hiperboost
Next Topic:Jzz30 Soarer Front pipe onto JZA70?
Current Time: Sat Nov 21 08:38:02 UTC 2026
Total time taken to generate the page: 0.0048849582672119 seconds
