Toymods » Tech & Conversions » speedo cable
old_mr2
speedo cable Tue, 15 March 2005 06:51 Go to next message
Guys
a fortnight ago i dismantled my dash and disables my AW11 warning chime put it all back together and every thing was sweet. Now two weeks later my speedo has stopped working. I undid the dash to inspect the cable and the speedo itself.
The speedo appears to be functioning i gently pushed a phillips head into the baqck of it and spun it, the needle and odometer were moving. So i think its OK.
I went out for a drive up the street (with dash undone) and the speedo cable connector was visible. The little male cable piece ( that drives the speedo ) was not spinning while driving.
Does this mean I have to replace the cable. Im pretty sure it does, thought i'd check. Cheers
Kyosho
Wollongong
Re: speedo cable Tue, 15 March 2005 07:47 Go to previous messageGo to next message
You could have a busted speedo drive...
Or the cable could be fugged...
sonwill
Lara, Vic
February 2005
Re: speedo cable Tue, 15 March 2005 09:43 Go to previous messageGo to next message
It is easy to unscrew the cable from the gear box, then you can turn the end of the cable and get a mate(if you have one) to watch to see if it turns at the other end.
old_mr2
Re: speedo cable Tue, 15 March 2005 11:09 Go to previous messageGo to next message
OK mate ill look into that but didnt i already do that by driving while watching the speedo end of the cable? It didnt turn while driving?
chjeers
PS whats the speedo drive?
jesseT18
Castle Hill, Sydney
Re: speedo cable Tue, 15 March 2005 11:13 Go to previous messageGo to next message
by spinning both ends of the cable you can diagnose that as the problem,, if thats what it is!
if you check both ends of the cable and its all sweet, your problem is a little more serious!
speedo drive is the gear in the gearbox that spins the speedo cable
Kyosho
Wollongong
Re: speedo cable Tue, 15 March 2005 11:30 Go to previous messageGo to next message
If the speedo drive has died, the cable WILL NOT MOVE...
Hence, you are either seeing the drive broken, or the cable jammed in your test...
What you need to do, is get under the car, get the cable out at the gearbox end, and spin it there, get a mate to watch in the car, and hopefully the cable DOES NOT SPIN (As that points the problem straight out... replace the cable)
if the cable spins, then the problem is BEFORE the speedo cable (Speedo drive, or the magnetic part that makes the drive move...
old_mr2
Re: speedo cable Tue, 15 March 2005 11:39 Go to previous message
OK thanks guys i will let you know. cheers
Previous Topic:Jzz30 Soarer Front pipe onto JZA70?
Next Topic:pod filter anyone? (corolla sportivo)
Current Time: Mon Sep 14 22:48:00 UTC 2026
Total time taken to generate the page: 0.0055010318756104 seconds
