Toymods » Tech & Conversions » runnin temp for 1ggte
Ray_GZ20
runnin temp for 1ggte Tue, 15 March 2005 10:22 Go to next message
installing thermos on my gz20 wonderin if anyone knew the runnin temp of the 1ggte what would be ideal temp for fan to switch on cheers
Re: runnin temp for 1ggte Tue, 15 March 2005 12:35 Go to previous messageGo to next message
About 10-12 degrees about the thermostat opening temp.
ddeane
PNG
Re: runnin temp for 1ggte Tue, 15 March 2005 22:14 Go to previous messageGo to next message
Gidday
Toyotas run low around 82 deg thermostat, and this is what I have in my 1ggte. I switch in the fans at 87 deg, but can't remember what temp it cuts out. If you want to keep you head gasket intact please do not have the fan come in at 10-12 deg above the planned running temp. of the engine.
Be careful with advise that you receive as often it is opinion - I received similar advice and it cost me an engine as I used a thermo switch for the fan that bought it in at 92 deg.
To be sure check with your local Toyota dealer and confirm the position with the Lexus 200.
Creaig
Re: runnin temp for 1ggte Wed, 16 March 2005 00:40 Go to previous messageGo to next message
My thermostat is 82 deg C.
The thermo's kick in at 94 and off at 84.
Works perfectly.
Granted that its not a 1ggte, but if you are blowing head gaskets for 10degrees above the thermostat level, then your motor was fucked beforehand.
sixworks
Newcastle, NSW, Australia
Re: runnin temp for 1ggte Wed, 16 March 2005 01:29 Go to previous message
You obviously don't want the thermo's to wait too long before switching on but at the same time you don't want them to be switching on and off too often. If you find they are then you have the temp set too low.
On at about 94 and off at 84 sounds reasonable and while I haven't measured mine it would probably be the same. Also note that some 1G's are fitted with 89 degree thermostats which I think is a bit high for Australian conditions.
Previous Topic:does my car need to be engineered??
Next Topic:Gearstick switch adjustment ... '85 MX73 Cressida
Current Time: Sat Nov 21 06:46:14 UTC 2026
Total time taken to generate the page: 0.013141870498657 seconds
