Toymods » Tech & Conversions » Setting Hiperboost controller
woofa347
Whyalla
Setting Hiperboost controller Tue, 15 March 2005 11:28 Go to next message
Hi, just interested on what settings everyone uses on theres? I just have the boost controller without the wastegate controller.
Its installed on my MX73 1JZ and when I took it for a test drive tonight it wanted to keep boosting past 16psi but It kept hitting fuel cut. I know the limit of the turbos are 15psi max and I want to keep it down to 10psi if i can. I havnt turned any of the nobs in yet because I thought this would keep it down to lowest boost level.Any idea what the stock boost level would be for a 1JZ with twin dumps, pod, and 3" exhaust with high flow cat and 4" cannon?
If I turn the screws in, wont this raise the boost level?
Any help would be much appreciated. Its the only thing left to do before my beasht is back on the road Very Happy
Re: Setting Hiperboost controller Tue, 15 March 2005 12:34 Go to previous messageGo to next message
Search teh Toymods.
Its been covered MUCHO
Have you looked at Celicamads site?
badboybubby
On Probation
Re: Setting Hiperboost controller Wed, 16 March 2005 02:00 Go to previous messageGo to next message
Can i get a pic of how u set it up ?
Re: Setting Hiperboost controller Wed, 16 March 2005 02:06 Go to previous messageGo to next message
Searching would have revealed this
http://members.optushome.com.au/jag7799/car/turboinst.jpg
badboybubby
On Probation
Re: Setting Hiperboost controller Wed, 16 March 2005 02:10 Go to previous messageGo to next message
Aww geez your a good sort crUZsida hold still while i give you a kiss Laughing
badboybubby
On Probation
Re: Setting Hiperboost controller Wed, 16 March 2005 07:11 Go to previous messageGo to next message
Mines got a black hose hanging of the top right hand side above the smaller blue one Evil or Very Mad where there should be a red switch of some sort ? what is it?
[Updated on: Wed, 16 March 2005 22:04]
Chris Davey
sunny coast, qld
Re: Setting Hiperboost controller Wed, 16 March 2005 23:05 Go to previous messageGo to next message
Anyone got details on how to install with single turbo and external wastegate? I had it setup before and mechanic said that there is no need for 2 boost controllers. I tried to explain that one is the wastegate controller but they just think I am stupid.
Bugman
Re: Setting Hiperboost controller Wed, 16 March 2005 23:08 Go to previous messageGo to next message
easy mate.. one hose the yellow on goes to the wastegate and the blue one goes to the source of your pressure.. somewhere on the inlet plumbing before the throttle body.
Re: Setting Hiperboost controller Wed, 16 March 2005 23:36 Go to previous messageGo to next message
google has all your answers.
external wastegates have TWO pressure sources.... a controlled source and a direct source. This makes the ext gate help your turbo build up higher boost levels faster using the differential pressure (AFAIK).
http://www.twincam.org/forums/uploads/post-20-1111016282.jpg
Chris Davey
sunny coast, qld
Re: Setting Hiperboost controller Thu, 17 March 2005 02:48 Go to previous messageGo to next message
The way I had it was how Bugman described it. But between the hiperboost and the wastegate I fitted the wastegate controller. The mechanic said this wasn't necessary.
I have rung Paul a while ago for instructions and I thought the way I did it was the way he explained. He has had an accident and hasn't sent the instuctions through yet.
When I get home I will get the sheet of paper that I have and explain it better.
Re: Setting Hiperboost controller Thu, 17 March 2005 04:05 Go to previous messageGo to next message
your mechanic is correct - the wastegate controller is not necessary, but it is useful.
Basically the wastegate controller blocks the boost path to the wastegate actuator until pressure reaches a certain level, thus keeping the wastegate shut and allowing the turbo to spin up faster.
External wastegates, as my picture demonstrates, have TWO pressure source lines. The one at the TOP of the wastegate is the one which has to come from your boost controller.
You guys should read some basic turbocharger books if you are having difficulties understanding.... i didnt know shit until i read some, and i have only ever had one turbo car for 3 months now - i would hardly call myself knowledgeable. Those books really do help you understand HOW they work, what makes them work more efficiently, and the different methods of controlling boost pressures.
Chris Davey
sunny coast, qld
Re: Setting Hiperboost controller Thu, 17 March 2005 04:26 Go to previous messageGo to next message
Funny you should say that. Ordered my copy of Maximum Boost by Corky Bell about a month ago. Should be here soon Smile
Thanks mate.
Re: Setting Hiperboost controller Thu, 17 March 2005 04:44 Go to previous messageGo to next message
nice one Smile
good to see an enthusiasm towards learning. Thats the sort of attitude i love to see!!!
woofa347
Whyalla
Re: Setting Hiperboost controller Thu, 17 March 2005 06:59 Go to previous messageGo to next message
I'd also like to know what that small black hose is on the right hand side above the smaller blue one that is suppose to have a red plug in it?
We've installed the hiperboost but its not controlling boost at all, the turbo just keeps spooling up until it hits fuel cut Crying or Very Sad
I'll find out exactly how it was installed by the mechanic because I know its different to what is shown in that diagram, but he says it does exactly the same thing...but obviously its not....LOL
Chris Davey
sunny coast, qld
Re: Setting Hiperboost controller Thu, 17 March 2005 08:00 Go to previous messageGo to next message
When I got my old mechanic to install the hiperboost (for simplicity as he was doing dump pipes) he also installed it incorrectly. I can't remember how now as it was nearly a year ago. Anyway, I was told that he was running 20psi like that so it sounds like your mechanic has done it the same way.
BTW that is an easy way to blow a stock engine Shocked
woofa347
Whyalla
Re: Setting Hiperboost controller Thu, 17 March 2005 08:02 Go to previous messageGo to next message
Yep sounds like what mines done :-S It hit 20psi a few times. Im going over to have a look now.
woofa347
Whyalla
Can anyone tell me what that little black hose does that is suppose to have the red plug in it? Is that suppose to be used?
woofa347
Whyalla
Re: Setting Hiperboost controller Thu, 17 March 2005 08:04 Go to previous messageGo to next message
I've lost my instructions on how to install it Sad
Chris Davey
sunny coast, qld
Re: Setting Hiperboost controller Thu, 17 March 2005 09:14 Go to previous messageGo to next message
on mine the red plug wasn't used so I would assume that the pipe that you have wouldn't be used.
woofa347
Whyalla
Re: Setting Hiperboost controller Thu, 17 March 2005 09:29 Go to previous messageGo to next message
oh ok, thats what I was thinking, that it didnt need to be used at all. But my mechanic has connected it upto the front wastegate Confused
badboybubby
On Probation
Re: Setting Hiperboost controller Wed, 20 April 2005 11:31 Go to previous message
Good luck getting instructions this is what I got
Quote:
heheee love your comments thats what you get for being a knob .must be hard to use without insructions .Thats the beauty of ebay nice people get awesome service fuckwits like you get no instructions . probably a slow piece of shit anyway did your mummy buy it for you ???? judt admit it you forgot to deposit the money then had a winge to ebay without contacting me first . if you had half a brain you have the boost controller working perfectly .......cant get it to work suck shit i adverised a controller not instructions
Dickhead
Previous Topic:How many "k" motors?
Next Topic:re-welding chassie, illegal?
Current Time: Tue Oct 20 22:38:06 UTC 2026
Total time taken to generate the page: 0.1067328453064 seconds
