Toymods » Tech & Conversions » Edit: 3T bore tolerances
hokey
Kilsyth, Melbourne
Edit: 3T bore tolerances Tue, 15 March 2005 21:08 Go to next message
hey all,
building a 2tg/3t hybrid so i will need every bolt torque spec that all you people with manuals have. head bolts, big ends, cam bearing caps and anything else you can think of. i know this may sound a bit broad but i don't really want to start up a million posts on every single bolt and i have searched with not much luck.
Cheers, Calvin
[Updated on: Sun, 20 March 2005 10:26]
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 2TG Torque specs Tue, 15 March 2005 22:10 Go to previous messageGo to next message
Dont go to overboard with torque specs. Use 3T specs for big ends, mains and for cyl head (add 5 ftlb). Just do the rest tight.
fade-e
Re: 2TG Torque specs Tue, 15 March 2005 22:12 Go to previous messageGo to next message
here they are in full
[url]http://forums.toymods.org.au/index.php?t=msg&t h=37347
[Updated on: Tue, 15 March 2005 22:13]
hokey
Kilsyth, Melbourne
Re: 2TG Torque specs Tue, 15 March 2005 23:20 Go to previous messageGo to next message
thanx alot fade. that is so helpful.
Cheers, Calvin
setsuna
Re: 2TG Torque specs Wed, 16 March 2005 00:31 Go to previous messageGo to next message
beat me to it fayde!
I found those while looking for 3TG specs when rebuilding my engine. Smile
fade-e
Re: 2TG Torque specs Wed, 16 March 2005 00:53 Go to previous messageGo to next message
also depending on how much you work the motor and want to build it you might want to consider adding up to 5ft/lb per setting as andrwevibert said
hokey
Kilsyth, Melbourne
Re: 2TG Torque specs Sat, 19 March 2005 22:37 Go to previous messageGo to next message
does anyone know the bore tolerances for a 3tg so i am just assuming a 3t Confused
Cheers, Calvin
hokey
Kilsyth, Melbourne
Edit: 3T Bore tolerances Sat, 19 March 2005 22:38 Go to previous messageGo to next message
does anyone know the bore tolerances for a 3tg or just a 3t i guess Confused
Cheers, Calvin
[Updated on: Sun, 20 March 2005 10:25]
hokey
Kilsyth, Melbourne
Re: Edit: 3T bore tolerances Tue, 22 March 2005 06:19 Go to previous messageGo to next message
bump
hokey
Kilsyth, Melbourne
Re: Edit: 3T bore tolerances Mon, 28 March 2005 22:01 Go to previous messageGo to next message
someone must know
big c
Re: Edit: 3T bore tolerances Mon, 28 March 2005 23:17 Go to previous messageGo to next message
hey buddy, i've got a 2t/3t with an 89.92mm bore. i don't think you want to go much more then that otherwise i'm sure it will get awfully weak.
i've seen 200hp at the flywheel with the same bore as mine and bucket loads of torque!!!
hokey
Kilsyth, Melbourne
Re: Edit: 3T bore tolerances Mon, 28 March 2005 23:21 Go to previous messageGo to next message
sorry i don't think i have been clear enough. i would like to know the factory dimesnions before you have to bore it and uprgrade the pistons. i would like to know to see if i need to get new pistons or if i can just hone and use the standard pistons.
cheers, Calvin
hokey
Kilsyth, Melbourne
Re: Edit: 3T bore tolerances Thu, 31 March 2005 04:18 Go to previous message
anyone?
Previous Topic:CT20B info
Next Topic:7mge-7mgte MX83 conversion and parts requred
Current Time: Fri Nov 20 08:14:33 UTC 2026
Total time taken to generate the page: 0.042550086975098 seconds
