Toymods » Tech & Conversions » 4k Won't fire
Megz
4k Won't fire Wed, 16 March 2005 03:38 Go to next message
Hey people, I was at work last night and just as i was about to go home when my could wouldn't fire.
It would crank alright but not fire. I was not in the best mood so this made it a lot worse.
So i thought screw this i'm going home. So i went back this morning and looked for obvious signs. i checked Battery, leads, plugs, fueses, dizzy and coil but nothing appeared to be wrong.
I tested the spark plugs and there was no sparking. I took the dizzy cap off and the was nothing broken or screwed.
So i am thinking what the hell is going on???
Also i noticed an ignition box. Could be something wrong with that?
Could the coil be fucked?
Something else wrong?
Anyone got any ideas about it??
Any help is much appreciated cause i don't wanna spend money as i am doing the conversion soon but i need my car.
Michael
Megz
Re: 4k Won't fire Wed, 16 March 2005 05:55 Go to previous messageGo to next message
Anyone??
purple_people_eater_1
Hobart, Tasmania
Re: 4k Won't fire Wed, 16 March 2005 05:58 Go to previous messageGo to next message
Same thing happend to me turned out to be the ballast resistor,
try turning the key over so that the engine lights are on take the dizzy cap off and rotor button, using a flat blade screw driver flick the points open to see if there is any spark there.
If not check the wiring to the coil then and the ballast resistor, check for any craking or just replace it for a about $5
if its old.
Megz
Re: 4k Won't fire Wed, 16 March 2005 06:24 Go to previous messageGo to next message
Alright cool thanks i'll try that. Any other ideas?
Michael
OldSchoolRolla
January 2005
Re: 4k Won't fire Wed, 16 March 2005 06:33 Go to previous messageGo to next message
replace points???? low fuel mayb???? my car use to play up use to just stall n not turn on again... My points were no good.
good luck let us know wa tit was causing ur prob.........
Megz
Re: 4k Won't fire Wed, 16 March 2005 07:01 Go to previous messageGo to next message
Yeah my car is still at work so i can't do anything yet.
It had 1/4 of a tank still, I've had no problems before this.
Thanks for the replies,
Michael
I'll let you know tomorrow when i get it done(Hopefully)
Megz
Re: 4k Won't fire Wed, 16 March 2005 08:45 Go to previous messageGo to next message
Hey guys nothing was wrong with dizzy. I have a feeling it may have something to do with after market coil thing. Its a black box connected to the ignition with really dodgy wiring.
So tomorrow night i have to do a dodgy towing job to an auto-electrician to have a look at it. Which is shit because i don't wanna spend money on this engine when it will be taken out in a few weeks!!
Oh well thanks for the help guys. I'll let you know what the auto-electrician says.
Michael
Re: 4k Won't fire Wed, 16 March 2005 11:29 Go to previous messageGo to next message
take off the balck box and connect the coil directly.
or get a jaycar HEi kit.
Megz
Re: 4k Won't fire Thu, 17 March 2005 03:07 Go to previous messageGo to next message
Yeah i would but there is so many wires going everywhere so i can't trace them.
Michael
Re: 4k Won't fire Thu, 17 March 2005 03:58 Go to previous messageGo to next message
maybe it's an immobiliser and it is doing its job?
connect points to coil and drive away.
Megz
Re: 4k Won't fire Thu, 17 March 2005 05:17 Go to previous messageGo to next message
I'll let the auto electrician fix it.
Michael
Megz
Re: 4k Won't fire Thu, 17 March 2005 23:29 Go to previous message
Well that black box was fucked to say the least. The wires inside had fully melted and stopped everything from working. Well $119 Crying or Very Sad later its working fine with the black box thing chucked in the bin and all new wires hooked up.
THanks for the help guys.
Michael
Previous Topic:1jz in a corona
Next Topic:Using a Dremel to grind Aluminium
Current Time: Sat Oct 24 15:49:13 UTC 2026
Total time taken to generate the page: 0.0060760974884033 seconds
