Toymods » Tech & Conversions » Help injectors!!!
japspec
Help injectors!!! Wed, 29 May 2002 12:10 Go to next message
Guys I've searched high and low to find out what is the ohms of the yellow injectors from a late model 1GGTE motor but cant seem to locate the info. Cry
I want to upgrade to the 1jz injectors, the're high impedance 13.8 ohms and I need to make sure my injectors run the same or less ohms than that.
Please any info on how I can find out will be great. Nod
japspec
Re: Help injectors!!! Wed, 29 May 2002 12:15 Go to previous messageGo to next message
Actually I think they would be the pale green injectors. It's a 1990 1GGTE.
ed_ma61
Lost in the K hole
Re: Help injectors!!! Wed, 29 May 2002 12:20 Go to previous messageGo to next message
crazy idea:
pull the ecu plug off an injector, and measure the inj resistance with a mulitmeter
otherwise, go to repco, ask for the bosch stock replacment part number for that engine, then go to that pdf page i posted, and look it up.
otherwise, ill have a look for you.
ed
bunny
North Sydney
Re: Help injectors!!! Wed, 29 May 2002 12:28 Go to previous messageGo to next message
ed, if you read this
i wasnt too impressed with you not showing up the other day
if you ask someone to get u a part and they buy it for u it is courtesy to at least pick it up and give them the money, as i dont have your number i cant say this to you over the phone
so a call would be appreciated
ed_ma61
Lost in the K hole
Re: Help injectors!!! Wed, 29 May 2002 12:53 Go to previous messageGo to next message
michael...
huh? ask you to buy a part? i never asked you to buy anything for me. you said you had one already, or atleast, that was the inmpression you gave.
as for not comming around, it turns out i spent the afternoon with nishad trying to figure out what to do re: diffs g/boxes and wheels after his 'encounter' with you and your ma61 deals. in that light, i didnt feel altogether obliged to make the hike up to chatswood. i dont know what the situation is there, so am not going to cast dispersions, but that afetrnoon, i didnt feel a whole lot like going outta my way.
if youve gone and bought it specifically at my request, my apologies for misleading you. what exactly have you bought, and how much was it?
ed
japspec
Re: Help injectors!!! Wed, 29 May 2002 13:44 Go to previous messageGo to next message
Oh yeh of cause, a multi metermeter. So the ohms that appear on the multimeter will be what the ecu is running at.
I tried to download that pdf file but I couldn't view it. I'll give it another go.
Thanks for the help
PS I saw your post on the optimax fuel when you picked that dudes post to bits. Cracked me up "info past down from generation to generation of mechanics " hehehe
kevz0r
Re: Help injectors!!! Thu, 30 May 2002 10:19 Go to previous messageGo to next message
i bought a set of injectors that came off a 1GGTE. Theyre yellow with the rounded type plug.
Turns out theyre the same as the 7MGE 295cc injectors, so check up the details of them on Matti and Helene's site
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Injectors.html
think its 2.7 ohms or thereabouts
Pete
gold coast
Re: Help injectors!!! Thu, 30 May 2002 10:55 Go to previous messageGo to next message
Japspec, I have a spare set of 1J injectors and fuel rail. Done 70000 Klms. If you need em.
Johnny
Sydney, OZ
Re: Help injectors!!! Thu, 30 May 2002 11:24 Go to previous messageGo to next message
I think you'll find the 1J are a side feed injector which aren't interchangable with the 1G through flows, Rotary 12A will fit and are rated with high flow rates.
Pete
gold coast
Re: Help injectors!!! Thu, 30 May 2002 11:28 Go to previous messageGo to next message
True, johnny. 1J injectors are side feed.
japspec
Re: Help injectors!!! Thu, 30 May 2002 12:45 Go to previous messageGo to next message
Johny:
"They arent interchangable with the 1G through flows" do you mean the spray pattern flow or ohms flow.
Dosen't the term "side fed" just refer to where the fuel rail is mounted on the injector? If so then if I get the matching fuel rail it wont matter? Yeh/Neh?????
Thanks for the help guys.
I'm still to get an multimeter and test the ohms flow on the ecu plug. I hope its safe to just pull one of those ecu plugs off and stick a mltimeter in there?!
Kevz0r:
Thank, someone else gave me that link previously but it dosen't contain a 1GGTE anywhere.
Thanks again
Pete
gold coast
Re: Help injectors!!! Thu, 30 May 2002 12:55 Go to previous messageGo to next message
The question??
Are any 1GGTE injectors side feed?? There are more than a few versions of them are there not??
Johnny
Sydney, OZ
Re: Help injectors!!! Thu, 30 May 2002 13:11 Go to previous messageGo to next message
Yes and No, the actually injector sits in the fuel rail. Fuel is feed from the side and straight through to the next injector, so in essence the injector acts as part of the fuel rail.
Again Yes and No. If you get the fuel rail you may be able to cut and splice the rail to suit the injector spacing on the manifold. Then you have to some how mount it so it won't move and also seal the injectors where they fit the manifold. Also major prob. would be if the Toyota fuel rail is a cast item (most late models are), how would you splice them to the right spacing? To do all this will set you back as much as simple swapping your injector over to 12A items which flow some where close to 330cc/min (ie very high) Impedance could be the same too...I'm using the green injectors from a 1G which where flowed at 150cc... Are you running a standard ECU? Again a problem as the ECU will have to be remapped for any injector change.
Johnny
Sydney, OZ
Re: Help injectors!!! Thu, 30 May 2002 13:16 Go to previous messageGo to next message
Quote:
The question??
I have seen any 1G's with side feed yet. Got to remember the 1G is and old style twin cam, the Newer 1G-FE found in the lovely IS200 looking are side feed from memory.
ed_ma61
Lost in the K hole
Re: Help injectors!!! Thu, 30 May 2002 13:25 Go to previous messageGo to next message
jonny:
"Rotary 12A will fit and are rated with high flow rates"
i think theyre hella high flow rates from memory arent they, like around 350cc up to 450 or something.
japspec:
"do you mean the spray pattern flow or ohms flow"
neither i think. i think he means whether the fuel enters the top of the injector body, or the side of the injector body. dont bother trying to make a side feed fuel rail...waaayyyyy too much hassle considering you should be able to get the right injector in the first place.
"I hope its safe to just pull one of those ecu plugs off and stick a mltimeter in there"
sure is. remember, youre reading the resistance through the injector, not the resistance in the ecu plug (dumb, but felt i should clarify)
Johnny
Sydney, OZ
Re: Help injectors!!! Thu, 30 May 2002 13:31 Go to previous messageGo to next message
Yeah, I know they were around that mark and had different flow rates depending on years, also had low impedances from memory too, but don't quote me, could be wrong.
jazae86
Re: Help injectors!!! Thu, 30 May 2002 14:14 Go to previous messageGo to next message
This is from an old autospeed post:
I take no responsability for the accuracy!!!!
Manufacturer Part Number cc per minute Colour Ohms lbs per hour Est. hp. each Test Press.kPa Vehicles Engine
Nippon Denso 315 light green 13.8 30.9 63.0 290 Toyota 7MGE
Nippon Denso 430 black 2.9 42.2 86.0 255 Toyota 7MGTE, 3SGTE
Nippon Denso 295 yellow 2.7 28.9 59.0 255 Toyota 7MGE
You also want to measure the injector resistance at the injector not the ECU. The line resistance will be negligable, and all you need to know is high or low. Above 12ohnm or below 5ohm.
Jaz
[edit to fix formatting]
[Updated on: Thu, 30 May 2002 14:15]
japspec
Re: Help injectors!!! Fri, 31 May 2002 09:53 Go to previous messageGo to next message
Thanks for all the replies guys. I feel so wanted! Cry
I still haven't got to the multimeter at work yet. Can't get out of the office!!!!!!!!!!
I'm sure to get it done tomorrow.
Jonny:
You said I would need the stnd ecu to be re mapped due to the new injectors. I've seen many sites on the net about upgrading to larger injectors ie 2jz supra that didn't mention anything about having to change the ecu, they did say there was some tuning to be done as the car in question ran richer, but thats what I want to cope with higher boost.
Thanks for all the info.
Hopefuly I'll be able to help out some poor sod like me in the future.
FYI
I have a mate that thinks theres a shop in town with a dyno thats sitting doing nothing, not even hooked up. Might be able to get it hooked up and running! Free dyno runs!!!! Should be able to doco the upgrades on the supra from stock. Once I figure out what to upgrade!!!
Johnny
Sydney, OZ
Re: Help injectors!!! Fri, 31 May 2002 10:16 Go to previous message
Yeah, the car will run rich, hence run more boost, but I think to run more boost, you'll need the fuel cut limit removed. You'll also be not reaping the full potential of the engine too. without the proper maps ie it could lean out in some areas and over fuel in others, which isn't just a matter of adjusting the timing. Sure, more fuel = more boost = more power!! but how long have these engines lasted doing this mod? Many times have they had to change the spark plugs due to fouling or lean out? and how often? Best off doing the change, sticking an EGO up it's arse, putting it on a dyno and having a look at everthing. I know it's a low cost mod, but any mod not done properly, especially when adding more fuel to the equation, could cost you more in the long run.
Previous Topic:what does your 4A-GE sound like?
Next Topic:Turbo Manifold
Current Time: Thu Nov 19 18:48:30 UTC 2026
Total time taken to generate the page: 0.0078120231628418 seconds
