Toymods » Tech & Conversions » Using a Dremel to grind Aluminium
Using a Dremel to grind Aluminium Thu, 17 March 2005 03:24 Go to next message
I've got some welded on my new manifold to grind down.
What bit for a dremel should I use?
http://au.dremel.com/html/products/accessories/gri nding.html
Bits are listed here.
I was thinking maybe 911 or 941 to get the bulk off, and then finishing with something finer, maybe 516, before polishing with sandpaper
Thoughts?
takai
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:27 Go to previous messageGo to next message
I use a little carbide cutter to get most of the stuff off, and then finish grinding down with a 911esque bit, and then finish with a cartridge roll.
EDIT: with a dremel you have to make sure you go slow, the torque isnt great and grinding alloy isnt easy.
[Updated on: Thu, 17 March 2005 03:27]
Do dremel make Carbide ones?
I was looking for them but didnt see any listed
takai
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:28 Go to previous messageGo to next message
Yep, its a dremel carbide. No idea on the part number though.
CLG
Perth, Western Australia
Use a burr to remove the bulk, then a stone to smoooth it out.
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:29 Go to previous messageGo to next message
I see this little puppy but I don't think its what I need
http://au.dremel.com/productdisplay/bit_template.a sp?SKU=542&Color=CC0000
takai
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:31 Go to previous messageGo to next message
In here:
http://au.dremel.com/html/products/accessories/car ving.html
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:33 Go to previous messageGo to next message
Ahh, one of the "HighSpeed Cutters"
I'll pick one up on the weekend.
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:36 Go to previous messageGo to next message
CrUZsida wrote on Thu, 17 March 2005 14:24
Thoughts?
i use these for nearly everything.
http://au.dremel.com/productdisplay/bit_template.a sp?SKU=420&Color=CC0000
the burrs are pretty useless with a dremel.
either that or a good file.
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:39 Go to previous messageGo to next message
oldcorollas wrote on Thu, 17 March 2005 11:36
You saying that the dremel doesnt have the torque to do the job?
If need be I'll start with an angle grinder, and finish with the dremel.
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:41 Go to previous messageGo to next message
Damn Double Posters...
[Updated on: Thu, 17 March 2005 03:42]
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 03:54 Go to previous messageGo to next message
CrUZsida wrote on Thu, 17 March 2005 14:39
not really a torque thing.. the burrs are just usually crap... they tend to fill up quickly with alloy and lose their edge quickly also.
the stones are useless with alloy as it coats the surface and again, renders them useless...
just my opinion tho.
fr shaping alloy, i'd use the 3M scotchbrite discs.. they eat thru it nicely.. and the soft ones polish ok as well.
Allan
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 04:44 Go to previous messageGo to next message
get serious
http://img217.exs.cx/img217/3869/stainless011.th.jpg
Very Happy
[Updated on: Thu, 17 March 2005 04:45]
Skip
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 04:53 Go to previous messageGo to next message
Dremmel's can do everything, don't you remember that tele ad?
Oh yeah they said they cant hammer, but im sure they have been used for this purpose, particularly when they burn out. Laughing
Sam_Q
S.E suberbs, Vic
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 05:51 Go to previous messageGo to next message
if you use a burr try dipping it into some lard, get it from your local supermarket. Apparently it lubes it up and stops the aluminium sticking
ed_ma61
Lost in the K hole
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 06:18 Go to previous messageGo to next message
find a dental equipment supply place, and ask to see their amalgum burrs... 400% better than the dremel ones, and cheaper too... will cut through alloy/steel/ti/ceramic you name it like hot knife + butter
dont forget to use LOTS of cutting lubricant when grinding alloy to prevent gauling of the tool
ed
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 06:30 Go to previous messageGo to next message
Thanks Ed, I was actually waiting your reply (hehe)
Will look into dental places.
Maybe I'll just book an appointment and flog something.
gold28
Madrid - Spain
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 23:15 Go to previous messageGo to next message
Supposedly you shouldn't use grinding stone type wheels with aluminium as the ally gets imbedded in the stone, heats up, expands and breaks the stone. Probably not too much of a problem with a dremel but on a bench grinder, a piece of stone coming off a the bench grinder at speed can do a lot of damage. I have never personally heard of it happening, but thought I should mention it.
Re: Using a Dremel to grind Aluminium Thu, 17 March 2005 23:20 Go to previous message
so does someone have a dremel and an amalgum burr I can borrow to mount my back seats? (I'm assuming this burr will be ok for widening holes drilled into my seat mounts)? I'm starting off with angle grinder + cutting disc and drilling holes in the area that needs to be removed, but need something to smooth and widen the area.
</hijack>
Previous Topic:4k Won't fire
Next Topic:2JZ GTE Fuse issue
Current Time: Sun Oct 25 00:20:16 UTC 2026
Total time taken to generate the page: 0.029958009719849 seconds
