Toymods » Tech & Conversions » Unleaded fuel filler restrictor - Where to buy
Skip
Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 04:45 Go to next message
As the title suggests, particularly in Perth
Cheers Smile
rob_RA40
c'town, NSW
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 04:49 Go to previous messageGo to next message
car importer/compliancer $25 they have the ones that holden and ford use.
wrecking yard destroy one from another car
both options may need you to weld them into place
Skip
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 04:55 Go to previous messageGo to next message
Thatnks rob.
I suppose i should have been more clear.
I wanted to try and buy an off the shelf type to weld in, not go chasing one at the f*ckers, sorry i mean wreckers.
rob_RA40
c'town, NSW
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 04:58 Go to previous messageGo to next message
yeah off the shelf one will be at an importer/compliancer
they use the same ones as ford and holden do but they arent pressed into the filler neck
$25
u can also steal a holen/ford fuel cap and use it in conjunction with these ones cause they have a thread in them wich makes it easier to attach cause u dont have to weld it half way down your filler tube.
ChuckLandwehr
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 08:31 Go to previous messageGo to next message
Skip, talk to your engineer. The requirement for an unleaded filler neck, has been made redundant, by the withdrawal of leaded fuel from the Australian market.
Even though the legislation has not been ammended, most engineerrs over this side of the country, now only insist on an "unleaded fuel only" sticker.
cheers Chuck.
toof
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 10:35 Go to previous messageGo to next message
my engineer wanted a filler restriction in my aw11 when i asked him about the fact you cant get leaded fuel he said its still in the rules so i still has to be done..
the commodores use a really simple system.. their neck if about a foot long then has a piece of hose with a clamp that goes to the rest of the system. just goto the wreckers and you can get them for about half of stuff all. then just adpot it to your current system the way the commodore does.. hose and clamp. thats what ive done and it works a treat.
YelloRolla
On your mum!
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 11:07 Go to previous messageGo to next message
wreckers usually give them away because they dont sell.
barned01
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 11:10 Go to previous messageGo to next message
yep with Toof on this one we did exactly the same thing to a Sigma. cut neck of commodore filler from a VN commodore and appropriate hose and clamp, cut filler off your car put rubber hose on your car and clamp, put commodore filler on other end of hose and clamp. less than 1 hour work. but you would need to go to the wreckers...although you could run in purchase the product cos i am sure they have some lying around and get out again within a minute and a half i reckon (try and get them to give you the rubber hose with it) if you have a phobia of them...or get a friend to go get it for you
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 12:41 Go to previous messageGo to next message
Lemme know how you go Skip, I'm keen to see what I have to do. If I only need a sticker I'll be heading out to a Subaru dealership for a "98RON only" sticker Very Happy
YelloRolla
On your mum!
Re: Unleaded fuel filler restrictor - Where to buy Thu, 17 March 2005 21:55 Go to previous messageGo to next message
I took the commondore neck and drilled the spotwelds out and welded it into the Corolla filler neck 2 or 3 weld spots and under an hour too.
Fattony
Re: Unleaded fuel filler restrictor - Where to buy Fri, 18 March 2005 02:24 Go to previous messageGo to next message
I got a hilux neck with mine and cut it just above the restrictor and welded the original part of the neck onto it. Made sure i had all the angles ect right, and booya i have a fuel filler neck with a restrictor and retain the original outside on the neck. I would have hated to put an ugly Holden Ford fuel cap on my ra23 where it is there for all to see
rob_RA40
c'town, NSW
Re: Unleaded fuel filler restrictor - Where to buy Fri, 18 March 2005 02:32 Go to previous messageGo to next message
yeah id only suggest the holden/ford cap if it was covered by a door flap like the bundera has.
for me KE35 and MX23 and all the other models with the dressed up caps not covered by a flap, its much harder exercise
[Updated on: Fri, 18 March 2005 02:32]
toof
Re: Unleaded fuel filler restrictor - Where to buy Fri, 18 March 2005 03:42 Go to previous message
yeah on the mr2 it has a cover. it isnt the most beautiful of setups but it works just fine if i ever get bothered ill take it all out and neatly weld it all together.
Previous Topic:Mark II diesel -->1J conversion
Next Topic:TA22 idler arm, is not the same asRA23/28
Current Time: Sat Oct 24 00:20:50 UTC 2026
Total time taken to generate the page: 0.0062708854675293 seconds
