Toymods » Tech & Conversions » W58 + xA6x = 2 different types of slave cylinder?
damz
Sydney, northshore
W58 + xA6x = 2 different types of slave cylinder? Thu, 17 March 2005 11:33 Go to next message
hey I am slowly getting my w58 manual conversion happening, but I just tried to test-fit the slave cylinder to the bellhousing and see if it would line up with the clutch fork and it seems like my slave is 'backwards'.
I tried to see if i could just flip it (so that it lines up with the fork) but the bleed valve will be obstructing it that way..!
Is there really two different slave cyls for the xA6x series?????
If its unclear what i mean, this is what i need it to be like:
http://www.projektile.net/images/slave.jpg
but the one i have looks like its the reverse, with the bleeder valve pointing "down" from the perspective of that image. Obviously that also means that the push rod of the slave cyl misses the clutch fork by about 6cms.
Whats the deal?!?
wilbo666
Re: W58 + xA6x = 2 different types of slave cylinder? Thu, 17 March 2005 11:41 Go to previous messageGo to next message
I think RA6X's have the slave on the drivers side... and hence it is mirrored!
You havent said what you are converting...but I can tell you SA63's and MA61's are on the passenger side of the bellhousing. Smile
[Updated on: Thu, 17 March 2005 11:42]
setsuna
Re: W58 + xA6x = 2 different types of slave cylinder? Thu, 17 March 2005 11:42 Go to previous messageGo to next message
nod nod...
MA61... supra... $36 Smiley =
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: W58 + xA6x = 2 different types of slave cylinder? Thu, 17 March 2005 11:47 Go to previous messageGo to next message
i could almost swear that the slave cylinder was on the pass. side.... ah well Razz u got the slave for the wrong side Smile
setsuna
Re: W58 + xA6x = 2 different types of slave cylinder? Thu, 17 March 2005 11:52 Go to previous message
ime not sure baout the W58
but I had the same problem fitting my J160...
the slave was wrong.
in the end I used a Supra slave with an extended 'rod bit'
that actually presses on the clutch fork park.
and it looks the same as that.
on the passenger side....
Previous Topic:tuning ignition??
Next Topic:88 camry, mods and convertions
Current Time: Sat Oct 24 04:01:11 UTC 2026
Total time taken to generate the page: 0.0049960613250732 seconds
