Toymods » Tech & Conversions » ae101 4agze conversion --> ae92 SX baby. . .Pls Advise
bayka
perth
icon7.gif  ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Thu, 17 March 2005 16:10 Go to next message
Hey ppl!
Its finally happening...i got a call from my supplier today telling me that he couldn't locate an ae92 MAP 4agze front cut so did i want an ae101 4agze f/c instead?
hmmm......YES!!!!!
Ive done a bit of searching but can't find specific details on differences of installing an ae101 ZE compared to the ae92 ZE.
Like all things done to car so far, (except exhaust) we're doing this ourselves so if possible could some you answer these questions or point me in the right direction for info as we were expecting to be using the AE92 ZE Smile
1. Will the ae101 still bolt straight up to existing eng mounts
2. Will my heavy duty exedy clutch from my 100kw 4AGE bolt onto the ae101 ZE?
3. Will your mum call me this weekend?
4. Will i be able to use the ae101 steering rack and front brakes?
5. Are there any little things i should look out for because of the ae101?
6. With the microtech mtx-8 ive got is 200hp@flywheel a realistic target? Im after absolutely punishable performance on a daily basis
Cheers heaps! Surprised
-daniel-
[Updated on: Thu, 17 March 2005 16:18]
Re: ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Thu, 17 March 2005 20:51 Go to previous messageGo to next message
there are only a few differences with the AE92 and AE101 4A-GZE frontcuts
1. All but one. The Rear gearbox mount (towards most rear of the car) is different. You need to buy an AE92 GT-Z engine mount from Toyota.
2. NO!!! Separate the gearbox and engine, measure the original clutch disc diameter and call Nick's Clutch in Brisbane. There are two sizes of GZE clutch - 225mm and 230mm, and they each have different pressure plate PCDs too!
3. Not fvcking likely
4. Front brakes, yes. See the brake conversion guide in the FAQ on http://www.twincam.org/forums since if the f/cut has superstruts there is a little more work involved.
Steering rack, also yes - but you need to retain the AE92 tie rod ends AFAIK
5. Not really. AE92 map and AE101 map gze's are virtually identical. AIr con lines are different...
6. Yes that is achievable. Get an ARC or similar topmount (replaces factory), a 175mm Nevo pulley set and a good tune. If in sydney i recommend Silverwater Automotive SServices - they are a Toymods sponsor.
bayka
perth
Re: ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Fri, 18 March 2005 01:01 Go to previous messageGo to next message
thanks WITZL thats exactly what i needed to know.
Also is it true about around 30% of ae101 ZE's coming out with LSD boxes?
Do any of them come in 6spd variants or is that just for blacktop?
-daniel-
Re: ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Fri, 18 March 2005 02:40 Go to previous messageGo to next message
6 sp was ONLY available on the AE111 blacktop 20v - Corolla Levin BZ-R
# re: LSD boxes. Easy to identify.
-> E58-11C = LSD
-> E58-474 = NON-LSD
-> E58-**5 = LSD
or just spin one wheel and watch the other... if they spin same way you have an LSD.
On the AE101, there was a much larger percentage with LSD boxes.
RSSTi
Melb, Victoria
Re: ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Fri, 18 March 2005 05:25 Go to previous messageGo to next message
101 rack will fit with 101 ends, i'm using one in a ae92.
bayka
perth
Re: ae101 4agze conversion --> ae92 SX baby. . .Pls Advise Mon, 21 March 2005 00:05 Go to previous message
ok cool, one more thing.
Is there some way i can keep my Heavy Duty clutch by bolting my 100kw 4age flywheel onto the ZE ??
I dont understand why it wont fit..
Previous Topic:R&R Heater in MX83 Cressida
Next Topic:Caster
Current Time: Sat Nov 21 03:29:13 UTC 2026
Total time taken to generate the page: 0.010849952697754 seconds
