Toymods » Tech & Conversions » 4age 16v head on 4agze block
driftpig180sx
4age 16v head on 4agze block Thu, 17 March 2005 21:34 Go to next message
I currently own a 4agte sprinter, the motor is originally a 4agze with turbo and exhaust manifold. I am just looking at ways for power gains and better drivablility. As I have been told the small port head is ideal for this setup(jdm 4age from levin/trueno, correct me if im wrong)
What are the specific gains in using the 16v head on a 4agze block? Is the small port ideal for this head conversion or are there other ways to fit/modify the big port? Does the head bolt straight on, and will it require any modifications to the inlet manifold?
all help will be much appreciated
[Updated on: Thu, 17 March 2005 21:36]
Re: 4age 16v head on 4agze block Thu, 17 March 2005 22:22 Go to previous messageGo to next message
all 4a heads are interchangeable with all 4a blocks.
HOWEVER: if you had a smallport 4agze, then your head is IDENTICAL to a smallport 4age. Likewise a bigport 4agze and 4age.
NB: if you have a bigport head currently, you will need a different intake manifold or adaptor plate if you decide to use a smallport head. I have done a couple of threads (one in particular being a guide to converting the FWD smallport manifold to RWD) which can help you here.
driftpig180sx
Re: 4age 16v head on 4agze block Thu, 17 March 2005 23:33 Go to previous messageGo to next message
Cheers mate, will do a search on the threads
Big T
Re: 4age 16v head on 4agze block Fri, 18 March 2005 12:04 Go to previous messageGo to next message
driftpig180sx wrote on Fri, 18 March 2005 08:34
Look up Bill Sherwood's site: http://www.billzilla.org/4agstock.htm
to find out the specs of the engines. The 4agze is already a 16v so I think you're getting a little confused with the heads/blocks. In a turbo setup, the bigport head seems better due to the ability to stuff more air into the larger ports. The AE82 4age also has the bigport head. You'll need to check what kind of head you currently have as the GZE came in both large and smallport heads.
Eddie.
d-shiznit
W.A
Re: 4age 16v head on 4agze block Fri, 18 March 2005 15:38 Go to previous message
NA bigport cams
Previous Topic:piston head design
Next Topic:Advice on Exhaust for 22RE ?
Current Time: Fri Nov 20 00:43:02 UTC 2026
Total time taken to generate the page: 0.0062558650970459 seconds
