Toymods » Tech & Conversions » new idler arm hitting crossmember in 3tgte ta22
rb20det
new idler arm hitting crossmember in 3tgte ta22 Fri, 18 March 2005 01:38 Go to next message
after i put new brakes on the car i noticed some of the bushes were stuffed and one of the idler arm bent. i replaced it but now at full lock it hits the crossmember, is this because of the conversion done dodgy or is it a common problem. i put old arm in but the rest of the front end is so out its causing steering problems (only minor) but im off to a advanced driving day soon and want it to be right.
ra23celica
Re: new idler arm hitting crossmember in 3tgte ta22 Fri, 18 March 2005 03:03 Go to previous messageGo to next message
Check the other current thread on idler arms.
Then get your car down to a suspension specialist ASAP and get it sorted.
If you are having these problems and then doing driving training days you will throw yourself off the road if your steeering is not sorted.
rb20det
Re: new idler arm hitting crossmember in 3tgte ta22 Sat, 19 March 2005 12:29 Go to previous message
bump, still doesnt answer my question. i use a ta22 idler arm same as my one except my one is bent so it doesnt hit the modified? crossmember. i just fitted nolathane bushes all round man the thing is so tight ill rattle my fillings out.
Previous Topic:Legalities of stuff...
Next Topic:Help! Brake Problems ~ Cost of items?
Current Time: Mon Oct 19 06:04:51 UTC 2026
Total time taken to generate the page: 0.071836948394775 seconds
