Toymods » Tech & Conversions » TA22 idler arm, is not the same asRA23/28
ChuckLandwehr
TA22 idler arm, is not the same asRA23/28 Fri, 18 March 2005 02:31 Go to next message
Somewhere in the aftermarket parts identification system, someone has incorrectly identified the TA22 and RA23 idler arm as being the same.
The TA22 idler arm is 10mm shorter than the 23/28 arms.
Both REPCO and RARE Spares, stocked the 23/28 idler as a TA22 item.
The only solution, is to take the old TA22 idler arm with you, when you buy a new idler arm.
Best bet is to buy it from a suspension workshop.
cheers Chuck.
Re: TA22 idler arm, is not the same asRA23/28 Fri, 18 March 2005 02:51 Go to previous messageGo to next message
Yeah i wish they would fix their damn books..
I had similar problem, wanted ra28 idler arm, they said ra40 is the same part number..
Got home all ready to fit it.. suprise suprise it didn't fit.
ra23celica
Re: TA22 idler arm, is not the same asRA23/28 Fri, 18 March 2005 03:01 Go to previous message
Thanks Chuck,
I found out this exact problem as well to when I went to buy this bit from an Auto1 outlet.
He said, yep, its the same from 1970 to 77, and having wrecked a TA22 and compared both, I said no way, your book is wrong.
I went to a suspension mob after that.
Mitch.
Previous Topic:Unleaded fuel filler restrictor - Where to buy
Next Topic:need info or specs on 7MGTE
Current Time: Fri Oct 23 21:57:30 UTC 2026
Total time taken to generate the page: 0.0053479671478271 seconds
