Toymods » Tech & Conversions » Sump pressure problems....urgent help please
ta23
Sump pressure problems....urgent help please Fri, 18 March 2005 02:43 Go to next message
Hey guys just after some pretty urgent help if anyone can help.
My TA23 with 3TGTE is currently getting an intercooler / turbo upgrade + other necessary mods. At present everything is hooked up and ready to be dyno tuned. The car idles and runs fine until it hits boost, when it hits boost it blows out white smoke.
The guys who are working on my car cant seem to work out the problem, the sump after being tested has a pressure of 5psi, my engines compression is perfect, they have checked the PCV valve and it is fine. Also my oil catch can has no oil at all in it.
If anyone has any ideas it would be greatly appreciated, this is the only thing that is stopping me from getting my car back, so yea I am very keen to get it sorted.
Mitch.
[Updated on: Fri, 18 March 2005 02:46]
Re: Sump pressure problems....urgent help please Fri, 18 March 2005 04:15 Go to previous messageGo to next message
Is the turbo ok?
MS-75
Re: Sump pressure problems....urgent help please Fri, 18 March 2005 04:56 Go to previous messageGo to next message
Hi mate-from what you describe, I'm relatively confident the problem is the pressurised sump. Although 5psi may only seem a small amount of pressure, it is more than enough to cause the turbo to leak oil past the rear seal (there should be virtually no measurable pressure in there if it's all set up correctly). The oil drains back into the sump and if there is 5psi in the sump, there's a good chance the oil will shove it's way past the seal and go into the housing instead.
Try removing the PCV valve all together, and run an open hose from the PCV hole on the rocker cover to your catch can, and then a line from the can to the airbox or the front of the turbo. (or you can just leave the catch can open to air-but it'll be a bit smelly)
Run the car again, and you should see virtually no measurable pressure in the sump-AND (I hope) no more oil smoke.
Even with brilliant compression, all engines will leak some gases past the rings into the sump, and on a turbo car, any residual pressure in there will generally upset the oil drain back and blow a bit of smoke.
Sean
ta23
Re: Sump pressure problems....urgent help please Fri, 18 March 2005 06:32 Go to previous messageGo to next message
RA28 - yea turbo has only just been rebuilt .... unless it wasn't rebuilt properly????
MS-75 - thanks very much for your reply, I will be sure to mention this to the guys who are working on my car, hopefully they can get it resolved early next week.
Mitch.
[Updated on: Fri, 18 March 2005 06:34]
allencr
tallahassee FL usOFa
Re: Sump pressure problems....urgent help please Fri, 18 March 2005 16:15 Go to previous messageGo to next message
i think you need other "guys" if these can't see what they've done to it & wonder why the intake boost & sump have the same pressure!!
i don't know anything about turbos, but i've got a feeling that the life of yours has been shortened because of its oil return/drain being pressurized.
CLG
Perth, Western Australia
Re: Sump pressure problems....urgent help please Fri, 18 March 2005 16:21 Go to previous messageGo to next message
Mitch,
The 3TGTE rockermcover has a steel pipe outlet in the front of the cover, normally connected to the inlet ducting - make sure that is either returned to the inlet ducting or preferably and oil catch can - when you use high revs for a pronlonged period of time, the excess oil in the head can come out, and will need to be caught somewhere. This outlet is also a quick and easy test to confirm the sump pressure problems 0 leave it off, and go for a run which would normally cause turbo smoke problems - I reckon the "Venting to atmosphere" will solve your problems.
YelloRolla
On your mum!
Re: Sump pressure problems....urgent help please Sat, 19 March 2005 07:36 Go to previous messageGo to next message
There is a small crank case vent box located at approx cyl #4 under the intake manifold (it uses a large line off the back of the plenum). The vacuum signal line MUST have a check valve installed and it must be correctly oriented - no check valve = boost pressure straight into the sump.
Another problem could be damaged rings or pistons.
ta23
Re: Sump pressure problems....urgent help please Sun, 20 March 2005 03:45 Go to previous messageGo to next message
allencr wrote on Sat, 19 March 2005 03:15
Is this true, can anyone confirm this??
Thanks for the suggestions CLG and Yellorolla, will definetly mention these to the people working on my car on Monday.
Will let you know if they find anything on Monday.
Mitch.
[Updated on: Sun, 20 March 2005 03:48]
Re: Sump pressure problems....urgent help please Sun, 20 March 2005 09:00 Go to previous messageGo to next message
pressure in the crankcase is usully an indicator for:
-failure in PCV system
-blowby
except during high-rpm the crankcase pressure should oscilate between a slight amount vacuum and a slight amount of pressure.
non-expert opinion: if you've pushed oil out thru the seals in the turbo, you usually stuffed them or shortened their working life.
a guess as to why you have this problem? they've plumbed up the engine with PCV system to suit a NA car (vacuum only in intake manifold).
ta23
Re: Sump pressure problems....urgent help please Fri, 25 March 2005 00:33 Go to previous message
cheers guys, turned out to be the PVC valve, so its all sorted now Smile
Previous Topic:Dellow JZ -> W5X Alloy bellhousing
Next Topic:Engineer Recommendation in Melbourne
Current Time: Wed Aug 12 10:11:03 UTC 2026
Total time taken to generate the page: 0.015491008758545 seconds
