Toymods » Tech & Conversions » Lengthening control arms
ta2272
icon2.gif  Lengthening control arms Fri, 18 March 2005 03:53 Go to next message
Have been looking at different way to get some camber and it looks like i need to lengthen my control arms to get any decent camber,
i have been considering chopping and welding a block in my ones to make them longer but i have heard that other people have installed different control arms in there cars which are longer, from another vehicle. i have a ta22 anyone know of some which a re about 20-30 mm longerand fit and is this legal.
Jason
wilbo666
Re: Lengthening control arms Fri, 18 March 2005 04:04 Go to previous messageGo to next message
Cutting and welding of suspension components is illegal unless done by a certified professional and xrayed afterwards....as far as I'm aware!
The best and most legal option is to search around for longer control arms, sorry can't help you there! Maybe try RA40 and RA60's?
Re: Lengthening control arms Fri, 18 March 2005 04:09 Go to previous messageGo to next message
Sigma Smile maybe someone can confirm they fit ta22? as I know they fit ra28, ae86, t18.
ta2272
Re: Lengthening control arms Fri, 18 March 2005 05:03 Go to previous messageGo to next message
well how long are sigma control arms. and do ta22 control arms fit ra28 and the rest or vica versa?
Jason
Re: Lengthening control arms Fri, 18 March 2005 05:38 Go to previous messageGo to next message
Sigma are 30mm longer than RA28. 330mm in total.
[Updated on: Fri, 18 March 2005 05:39]
ta2272
Re: Lengthening control arms Fri, 18 March 2005 11:51 Go to previous messageGo to next message
do you have the dimensions of the busher were the bolt goes through and also, does it have the same system were there is a ball joint were the steering strut shoe sits on?
Jason
EVOSTi
cambo
      no
Re: Lengthening control arms Sat, 19 March 2005 02:35 Go to previous messageGo to next message
http://img50.exs.cx/img50/9449/pic21zb.jpg
these are my rose jointed control arms, they are great cause there is heaps of adjustment, but they are illegal. tho i doubt you'd ever get caught with them, but if your ever in a fatal accident you'd prob get shafted.
ta2272
Re: Lengthening control arms Sat, 19 March 2005 03:23 Go to previous messageGo to next message
not hose adjustable arms look great but i am aiming for somthing legal. ie replacing it with another cars, arm.
thanks.
Jason
EVOSTi
cambo
      no
Re: Lengthening control arms Sun, 20 March 2005 08:13 Go to previous messageGo to next message
well then yeah people like the sigma arms, but they give you a fair bit of camber, so you might want to go for adjustable strut tops to back it off a bit.
YelloRolla
On your mum!
Re: Lengthening control arms Sun, 20 March 2005 09:34 Go to previous messageGo to next message
You were talking about lengthening the originals by welding a block in!!!
This is for racing only (not suitable for road use)-
You can get another set of control arms, cut both sets so that if you add the inner end of one and attach it to the outer end of other, you will get your increased length (30mm is a lot) box the welded joint area with a flat plate.
ta2272
Re: Lengthening control arms Sun, 20 March 2005 11:35 Go to previous messageGo to next message
were woudl they have measured the 330mm from edge to edge or from center of the bolt and center of the ball join.
because the ta22 one is about 35cm's long edge to edge and about 32 center to center, anyone know some control arms i should try.
yellow rolla i want a legal solution to lengthening control arms any suggestions.
Jason
Turbo_Tim
Townsville
February 2005
Re: Lengthening control arms Sun, 20 March 2005 11:59 Go to previous message
We used sigma control arms on the T18, worked good. Just had to angle grind down the back of them which rubbed a little and cut down the crush tube and sand down the bushes where it attaches to the chassis.
Havent measured the camber, looks good though Smile Wider front track than rear, might be an issue on a road car?
If the sigma ones do fit Ta22's, make sure you get one pieces from an early sigma, the later models have bolt on ball joints and are apparently longer.
Im sure every wrecker has an abundance of sigma;s, ours did at least.
Previous Topic:1jz power outputs
Next Topic:ST162 problem
Current Time: Sat Nov 21 03:16:38 UTC 2026
Total time taken to generate the page: 0.0045139789581299 seconds
